How to adjust headlight height?
Old May 11, 2004 | 02:21 PM
locc_510's Avatar
I know there's a very easy way to do this, I saw it in the extremely useful topics section. But the links to the pictures did not work and I found the descriptions to not be enough without the pictures. Anything would help. Please be very descriptive as to where and what the parts look like though, thanks!
Old May 11, 2004 | 03:43 PM
CT3.2's Avatar
The CL Crazy
I need to know this info also. The picture don't show up.
Old May 11, 2004 | 04:57 PM
Titand19's Avatar
East Coast Boost.!
it's a 10mm silver bolt on the rear of the headlight under the hood. It's pretty obvious if you just look. it's dull not a polished bolt.
Old May 11, 2004 | 06:10 PM
farberstyle's Avatar
something witty
a ratchet should work fine, but make sure and not do it too much. you dont notice it against your garage door, but from 150 feet away, it makes a HUGE difference.
think 1" above normal from 3 feet away = 50" above normal from 150 feet. above the roofs of most passenger cars.
Old May 11, 2004 | 06:25 PM
joeshmoe's Avatar
My Home Planet
Be sure not to tighten the bolt to much because the thread hole is plastic and it will strip the threads.
Old May 11, 2004 | 07:36 PM
NiteQwill's Avatar
Adventurist.
Don't forget:
Vertical cutoff (or the "cup" of the beam) should be two inches down from the center of the centered horizontal line when parked on a level surface 25ft away. This allows plenty of visibility at night w/o blinding other drivers.
In a crude drawing:
--------+---center----+------ (stock vehicle height)
2 inches @ 25feet
--------LIGHT SHOULD HIT HERE------
<25ft>
CAR-------HL-------HL--------CAR
If further clarification is needed, i'll draw it in PS.
Old May 11, 2004 | 07:51 PM
NiteQwill's Avatar
Adventurist.
Here's a crude picture:
Don't graffiti!!! use masking tape....
Adjust according for every inch of drop if you have one. For example, you''re dropped two inches in front from stock. No need to minus 2 inches from stock height, because you're already there! Dropped 1.75 inches, subtract .25, etc. etc. Dropped 3, add 1".
If you're really really a perfectionist, take your car to a auto lighting shop, they hook it up to a HELLA Laser Alignment machine and it will be perfect!
Old May 11, 2004 | 10:03 PM
pimpscls's Avatar
THE SILVER BULLET
ill try to find em, ive been looking for them since i lowered my car in october
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
4drviper
Sep 23, 2015 07:42 PM
