Hope Systems, Inc.
#202
I NEED MONEY!
Originally posted by scalbert
I have someone lined up for testing the RES plate but if things don't work out or I need others I will definitely drop you a note.
Thanks...
Thanks...
Yeah, even if u have anything else that needs to be tested I'm here... just call me 404-461-3588
#204
I went by the machine shop today but he was tied up with getting one of the CNC machine running. I had several pieces for them to look at:
Machine the current RES plate for the new configuration
Look at what it will take to P&P the manifold
Look at porting the TB or machining a new one
Machining mounting brackets for the radius rod
I would like to get the RES plate done in a week so I can get to the dyno within two weeks. I also want the radius rod brackets done so myself and others can test them at the track within the next month.
So by the end of July we may have available:
RES Plate
P&P Manifold
Ported or New Throttle Body
Torque Arms (Radius Rods)
I'm also going to check on a small exhaust change which may or may not be available.
RES Plate
P&P Manifold
#205
#208
Flap.
scalbert, i know that your personal intrests and porlly the bulk of your customers, but i was wonderign if you had an idea of which parts would be made with a j30a1 application
#209
#212
Originally posted by motioneffects
Scalbert, I have the E-manage already but how much is it for just the PnP harness?
#213
*giggles like a school girl*
#214
BTW, I have the parts on the way for the radius rod and it should be a bolt on item. My first one will require a braket to be welded but I am trying to find a way to get away from that.
The unit will be removeable for street duty as there is some ground clearance issue currently. But it would not take more than a few minutes to bolts up at the track.
#216
Originally posted by blader
OK this might be a stupid question .. but about the torque arms. will they affect the ride at all? make it more rough?
That said, no, this will not affect the ride quality at all.
#217
Spectacular Aroma About
http://www.sbmsinc.com/photos/radius_0.JPG
#218
That is the future plan.
I first want to see how well some bolt on units will work with eliminating wheel hop. I expect it to be successful and when proven I will continue with development. That includes replacing the stock pieces.
#219
One more thing my father-in-law and I were going over yesterday. The brakes parts development may also be accelerated. We beleive we can come up with a new kit that will use Wilwood 4 piston calipers on 13.0 x 1.25 inch rotors. The rotors may end up being slightly smaller though but we'll see.
I should have some parts in soon and will start test fitting everything.
Initial projections are to be in the $850 range for the front set.
#220
13.68 @ 102.56
#222
steve, i want those brakes.
#223
///M POWER
1 Post
damn i just read all 9 pages of this, for some reason i never looked at this thread cause i thought it was for the s/c guys
but for 300, res would def be the shit
steve you are the fuckin man, nice work
#228
#231
Bleed Honda Blue
Wow, I saw your site. How much is the PnP hardness alone? It says pre-program for Supercharge with high boost pulley(add$125). So all I need it to pulg the e-manage into my car and I am ready for high boost? or do I still need to fine tune it in a dyno shop?
http://www.hopesystemsinc.com/engine...trols_Main.asp
#232
do u still have the orginal link that explained exactly how res works?
#233
#235
Audi S4 driver
considering I dont think he's even started designing the cams yet I think it'd be hard for him to tell...
about the brakes, I as well hate my brakes .. and 850 sounds alot better than 1300 for wilwood, 1700 for rotora or 2300 for brembo. I'd be in for your brakes.
#236
Originally Posted by darrinb
scalbert, what would you expect my car to put down to the wheels with i/h/p/u-chip/res/ and your cams package??
#237
#239
Once we get farther down the road and cams are being developed will there need to be different cams for different applications? Specifically the Uni-Chip? I know it is never good to install cams without proper tuning. Just curious if different cams will be used for NA no chip/NA chip/FI
#240
Bleed Honda Blue
Originally Posted by scalbert
I would say yes except for you having a 3.5L engine. This may require more fuel per PSI boost. Unless you see the A/F ratio it is just a guess.
