Hood alligned, or is it??
Old Jul 23, 2001 | 03:04 PM
Scooter's Avatar
'Cooter
ok, so it looks like my hood is alligned when i examine the gaps next to the fenders, but when i look at the front grill, the sheet-metal on side of the grill is out of allignment from the bumper by like an inch, and the other side is perfectly aligned...what's up with that?? i thought of any possible reason that caused this, i.e. dropping the hood closed, pushing the hood down after resting it into place, etc...i could push the front grill back so that the sheet metal and bumper allign properly, but when i let go, it falls back out of allignment...anybody have this problem?? could the bumper really b out of allignment??
Old Jul 25, 2001 | 02:11 AM
blazerbob1's Avatar
Hood near windshield is higher than fender
creating a small gap. Talked with my friends
who own a body shop and they would raise the
fender to match the gap. Well, after thinking
about it, am just going to leave it alone.
Quality control poor on ever allowing this car off line. The other is right exhaust pipe
that hangs lower than left.
Old Jul 25, 2001 | 03:39 AM
HellaWhat's Avatar
*Hella* isn't a word.
On my car u can feel that the hood isn't flush with the rest of the car. On the trunk, you can tell it's about 1/4" too far to the left when closed. Seems common...
Old Jul 25, 2001 | 05:20 AM
KavexTrax's Avatar
yes it is common but not normal.
my trunk is misaligned too.
gona ask the dealer about it during the 7500 checkup
Old Jul 25, 2001 | 10:55 AM
macon's Avatar
Also the doors are not alligned properly top to bottom.
Old Jul 25, 2001 | 04:19 PM
jdl75's Avatar
Originally posted by Scooter:
<STRONG>ok, so it looks like my hood is alligned when i examine the gaps next to the fenders, but when i look at the front grill, the sheet-metal on side of the grill is out of allignment from the bumper by like an inch, and the other side is perfectly aligned...what's up with that?? i thought of any possible reason that caused this, i.e. dropping the hood closed, pushing the hood down after resting it into place, etc...i could push the front grill back so that the sheet metal and bumper allign properly, but when i let go, it falls back out of allignment...anybody have this problem?? could the bumper really b out of allignment??</STRONG>
The most likely problem (w/o looking at the car - a high-res photo would help) is a hood out of allignment. I can give you the factory fix if you would like it (I am a former HAM-MAP Engineer in Weld Dept, 1997-2000).
Open the hood, and raise it so that it is level, as in parallel to the ground. Grab hold of the metal on either side of the grill (NOT the grill itself!) as close to the sides as possible. While lifting on the low side, push down on the high side. You want to do this in a jerking motion, as opposed to a fluid motion. Don't apply anymore force than you would to close the hood.
Check allignment after every torque or two. If you over-compensate, simply reverse the procedure. This is how we allign them in the factory.
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
dirleton
Sep 28, 2015 07:05 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
BookemDanole
Sep 11, 2015 04:53 PM
