Is this the hole in the firewall....?
Old Sep 2, 2001 | 01:45 PM
kensteele's Avatar
Under the hood that leads into the driver's compartment? Is this the hole, does anyone know? TIA
Old Sep 2, 2001 | 02:12 PM
Stuck'N'SS's Avatar
Are you talking about the hole to pass a powerwire through for the stereo? If So then that is not the hole that I used. I actually used a hole that has other wires coming through to the passanger compartment.
That hole, is on the Drivers side, far right and kinda up high. There you should see a bunch of wires going through a hole that has a rubber gromet. In order to pass anything through the hole you wil have to punch through gromet.
Might a suggest a pen with the wire taped to the end. That is how I got my 4 gauge through.
Old Sep 2, 2001 | 02:52 PM
kensteele's Avatar
Yes, to pass power wires from the inside to the battery under the hood. Is this the rubber grommet? Mine doesn't have any wires going thru it presently.
[ 09-02-2001: Message edited by: kensteele ]
Old Sep 2, 2001 | 03:56 PM
fbazakos's Avatar
on bin laden
ken, remeber the hole i showed you when i was down in KC?
here is how you find it. inside the drivers side, above the gas pedal. you should see the insulation a bit loose. pull it out, shove a screw driver thru. there is rubber covering the hole on the engine side. you can see it by standing in front of you car -- put your head down close to the grill, and look above the strut bar. you will see it, close to the top of the bay, just right of center.
Old Sep 2, 2001 | 08:08 PM
kensteele's Avatar
Originally posted by fbazakos:
<STRONG>ken, remeber the hole i showed you when i was down in KC?
here is how you find it. inside the drivers side, above the gas pedal. you should see the insulation a bit loose. pull it out, shove a screw driver thru. there is rubber covering the hole on the engine side. you can see it by standing in front of you car -- put your head down close to the grill, and look above the strut bar. you will see it, close to the top of the bay, just right of center.</STRONG>
Yes, I remembered that you showed me but two week later, everything looks different now. I'll go take a second look according to your instructions, thanks. Don't want to punch out something by mistake.....
Old Sep 2, 2001 | 09:06 PM
kensteele's Avatar
Confirmed. The previous two pics are the pics of the hole thru the firewall. As was said, inside the passenger compartment, remove this grommet and poke a screwdriver thru, you'll see it on the other side in the engine compartment. Thanks guys.
Old Sep 3, 2001 | 03:15 AM
SilverKnight's Avatar
Retired. Not available.
Originally posted by kensteele:
<STRONG>Yes, to pass power wires from the inside to the battery under the hood. Is this the rubber grommet? Mine doesn't have any wires going thru it presently.
[ 09-02-2001: Message edited by: kensteele ]</STRONG>
Yup, that is it. Here is mine with the power wire.
Old Sep 3, 2001 | 08:29 AM
Chris's Avatar
- daemonichris -
what?
Old Sep 3, 2001 | 11:48 PM
Scorpius's Avatar
Old Sep 3, 2001 | 11:51 PM
kensteele's Avatar
If you want to run a wire from the main battery under the hood to the inside of the vehicle, use this hole in the firewall. It's the easiest and cleanest way to go from inside the cabin to outside the cabin.
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
lowgrowl
Sep 26, 2015 05:18 PM
