HLSD converting the auto
Old May 30, 2003 | 08:40 PM
typeR's Avatar
so ericL...scalbert allmotor any other tech heads do any of you have any thoughts on the fesibility of converting the auto trans to the limited slip from the 6 speed and ...what would this do to the gear ratio if it can be done?????...to add some more specualtion power ,not that it's the same car but an auto 350Z did this and got a little closer gear ratio out of the deal...
Old May 30, 2003 | 08:42 PM
mattg's Avatar
so you would do it for the gear ratio? cuz the hlsd doesn't seem to help the 6mt hook up any better
Old May 30, 2003 | 08:50 PM
darrinb's Avatar
///M POWER
your right, all the 6speeds w/ nice #'s are on DR's
Old May 30, 2003 | 09:08 PM
typeR's Avatar
hey maybe they need driving lessons...but all i know is ...if i go 2.0 with one wheel drive im gonna be faster with 2
Old May 30, 2003 | 09:13 PM
mattg's Avatar
i don't think any cl has broke 2.0
is our diff. completely open? the other tire never has traction?
because i know i've been able to slide my front end before. also, there is vht stuck on both front tires after a few runs at the track.
Old May 30, 2003 | 09:21 PM
Mike's Avatar
feathering a clutch and feathering the accelerator on an auto are 2 completely different animals.
Old May 31, 2003 | 12:57 AM
joedokes28's Avatar
You know I'm no drag racer, but the reason the 6spd doesn't hook up is because there is just no traction with street tires. I shit you not, you can pop the clutch at IDLE and both tires will break loose. I did this in my driveway on accident once I think the HLSD would help the 6-spd alot more on a road course than at the strip when compared to the auto.
Old May 31, 2003 | 01:06 AM
Bluto's Avatar
Find beauty in dissonance
I think the auto is well balanced up front, the half shafts and what not. Isn't the HLSD more help on a course (turns), not a strip? At a certain load, doesn't the HSLD slip open anyway?
Old May 31, 2003 | 02:39 AM
bullaculla's Avatar
I don't think you can. I had a friend in parts dept look up the parts needed to install (i had an auto) the HLSD. the case is different. so you need to change the case.
Old May 31, 2003 | 10:08 AM
scalbert's Avatar
I seriously doubt that you could mechanically fit it without major work. But anything is possible.
But with regards to traction limitations with the HLSD; they still exist to a great extent. I would say that in straight line full throttle pulls the HLSD does more to keep torque steer at bay but will aid in launching to some extent.
The real beauty of the HLSD is in on throttle turns; this is where it shines over the automatics open differential. Having taken the same turns in both cars the manual version hugs the turn tighter with noticeably less push through the turn.
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
