Hi-Beam Bulb Removal ?
Hey guys,
Whats involved in replacing the hi-beams in our cars ? Looks as if a bunch of stuff is in the way on the drivers side.
Any help is greatly appreciated.
I swapped mine out for the OptiBlue bulbs about a month ago, for the driverside remove the battery cover and the coolent bottle as stated above...and it helps to have a phillips screwdriver attachment for your rachet set. It was impossible for me to get a screwdriver horizontally and get at the three scres which hold the bulb in place. You'll need a screwdriver which bends at the end to form the "L" shape or get the socket/rachet attachment. Took about 15-20mins
Originally Posted by fuzzy02CLS
On the drivers side just the coolant reservoir comes out. It slides up off a bracket.
all you gotta do is remove the battery cover, unscrew the cap on the coolant resevoir tank (Be careful to not spill any coolant) and simply lift the tank out of it's socket.
ripit
09-26-2015 06:19 PM
