Here is the template.
Old May 15, 2001 | 01:10 AM
SilverKnight's Avatar
Retired. Not available.
What do you need?
- Philip screw driver.
- Slot screw driver.
- 10mm socket and ratchet.
- 3 feet of gutter guard. You could get a whole roll for $2.47. I prefer the thinner type because it's easier to work with.
- A strong pair of scissors which I forgot to include in the pic.
First, pop the hood and remove these bolts with 10mm socket.
Use a flat head screw driver to press down the tab on upper side of these latches.Carefully pull out the whole piece and set it on something soft (rags, carpet, ect.) so you dont get the outter trim scratched.
Remove all the screws on the back of the piece except for those that hold the "wing".
Cut 3 ft of gutter guard and set it on top of the grill piece. Try to align it careful so that it would cover the entire grill piece.
Put the Acura symbol back and keep it in place with 2 screws. Dont tighten the screws all the way. We'll need to adjust the screen later.
Cut the extra mesh with a strong pair of scissors leaving about 1/4in bigger than the grill piece. Be careful with the mesh edge, it's sharp.
Be sure that you dont cut the mesh much bigger than the piece or not big enough. Bigger=problem with fitting the outter trim back. Not big enough=the mesh will not be held in place tightly by the outter trim.
Put the outter trim back on and secure it with the screws that you removed earlier.
Put the whole piece back and secure it the nuts that you removed earlier.
Done.
Part cost $3.00
Labor 30-60min
The good feeling seeing your DIY (do-it-yourself) job: Priceless
NOTE: if you wanna paint the mesh, do all the steps first so you can fit the mesh back easily after you paint it. Then remove the mesh and paint. That way you wont get your new paint job scratched while trying to fit the mesh on the piece.
Next weekend project.
Adding 2 amps to the existing Bose system. If y'all are interested, I'll do a template.
'01 Silver CL-S
Painted Mud Guard
Silver Aluminum Pedals
Kenwood Amp with 10in. Pioneer sub.
(modified) CAI.
My Car
[This message has been edited by SilverKnight (edited 05-15-2001).]
Old May 15, 2001 | 01:13 AM
soopa's Avatar
The Creator
Beautiful!
I will add to the FAQ now and put as an article in the garage tomorrow!
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow FogsValentine 1Xephyr CAI
"Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. That's relativity." -Albert Einstein
Old May 15, 2001 | 01:19 AM
eclipse23's Avatar
Moderator Alumnus
I'm doing this tommorow, will post pics.
01' Acura CL Type-S
Piaa 19169 Bulbs
Valentine1 Pig Detector
CompTech Exhaust
Xephyr Cold Air Intake
Founding Member of the NO SCRATCHED RIMS CLUB
01'Acura Integra GSR
Old May 15, 2001 | 01:23 AM
soopa's Avatar
The Creator
Someone wanna give instruction for doing this to the hole in between the road lamps? Or even the roadlamp holes if you take the lamps out?
Old May 15, 2001 | 01:46 AM
tw1112's Avatar
Great instructions! Good job!!
Tw1112
Old May 15, 2001 | 03:41 AM
KavexTrax's Avatar
exceeellent!~
- Kvit -
2001 CL-P Monterey Blue, Parchment interior
• Polarg BlHybrid M-6 Road lamps
• Polarg/PIAA super white interior lights *bling bling*
• HP Quantum 28 -- 31% metallic tint all around
• [Photopoint Album Pics]
Other
• [Yamaha Home Theater Gear]
• [DVD List]
Old May 15, 2001 | 04:32 AM
Simpleman's Avatar
the last one alive
What about rust?
Old May 15, 2001 | 08:52 AM
Satin Slayer's Avatar
aka gimmesomesugar
Can you remove the polished part behind the mesh...that long piece on either side of the Acura symbol? Since I would like to use black mesh, I don't want to see any polished parts behind the mesh...I want to have it totally black behind the mesh.
[This message has been edited by Satin Slayer (edited 05-15-2001).]
Old May 15, 2001 | 09:16 AM
JRock's Avatar
Old timer
Is it just me or does the Blose system need more than just two extra amps? Like maybe two subs, two better 6x9s, etc.
Btw, nice job with the grille!
-J
2001 CL-S Aegean Blue/black interior spoiler, wheel locks, no-navi
Stock for now.
Old May 15, 2001 | 10:27 AM
<font face="Verdana, Arial" size="2">Originally posted by Satin Slayer:
</font>
You can remove it. Just take out the screws on the middle horizontal bar. I dont know if it will look good or not because the "wing" is very thick. Remove it and you'll know what I mean.
I would check with an Acura dealer to see if they have the "wing" available for cheap. If yes, buy an extra piece and paint the current one black.
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 15, 2001 | 10:31 AM
<font face="Verdana, Arial" size="2">Originally posted by Simpleman:
What about rust?</font>
I wouldn't worry about rust.
1. The mesh is made of aluminum.
2. If it rusts, I'll redo it. The whole process doesnt take long. I took the mesh out to do the template and put it back in less than 30min.
3. If you are still worried, you can paint it.
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 15, 2001 | 11:28 AM
NOVAwhiteTypeS's Avatar
I personally like the painted black. the silver kinda looks cheap. JMO
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter.Polarg m-6.
Comptech Headers,Springs,Sways, Eurolite Xenon Crystal high beams.Polarg m6
gtech 0-60 6.03 w/ 438 pound load. preheader.
Old May 15, 2001 | 04:57 PM
langjae's Avatar
do it yourself, !
I'd like the amp install if you can get that in. Great job! I was thinking about doing that in the lower part of the bumper.
j
2001 Acura CL Type-S
Black - Ebony Interior - Spoiler - 20% Tint - Cleared Headlights
2000 Mercedes Benz E320
Black - Black Interior - Nav - Chrome AMG Rims
Old May 15, 2001 | 05:13 PM
Samer007's Avatar
Smack My B*tch Up
Aluminum does not rust !
Black 2001 Acura CL-S W/Nav 20%,35% Tint, Polarg M6 lamps
Live To Drive!
Old May 15, 2001 | 05:21 PM
spiroh's Avatar
SilverKnight,
Tall props..do you have pics of it on the car? And I definately will be interested in the Amp install.
Thanks,
Spiro
Black/Black 2001 CL-S
Random Technology Cat
RED AEM CAI
Polarg M6 Roadlamps
Old May 15, 2001 | 05:41 PM
synth19's Avatar
Looks sweet! Can you post a pic of the final product on the car? Thanks
g
'01 Silver TYPE-S (navi)
  • Spoiler
  • Comptech Springs
  • 18"ADR Enigma & 225/40
  • 35%tint all around
  • Polarg M-6
  • Xephyr CAI
  • Comptech Headers
  • Comptech Sways
  • Denso Iridium Plugs
Click here for pics of my CL!
Old May 15, 2001 | 05:51 PM
H@mmerm@n's Avatar
My other car is a 350Z
I cut and installed the mesh grill from the same stuff a couple weeks ago. Here's a pic:
http://www.2carlsons.net/car/cls/H4mm3rm4n/Grill1.jpg
Overall, I wasn't entirely satisfied with the result. I thought the grill material was a bit too shiny, so I disassembled it and spray painted it a gun-metal dark grey. After that the grill itself looked better, but then the black wing support really stood out behind the grill (I had already removed the chrome wing).
My $.02: I think no matter what color the Gutter Guard is (painted or otherwise) that the whole front grill won't look trick unless the black wing and smaller black supports are hacksawed out. The only piece I would leave is the centerpiece necessary to hold the Acura emblem.
I didn't have the guts to try this, so I returned my grill to the factory look.
Mike
2001 Satin Silver CL-S
Comptech headers, exhaust, sways; AEM CAI; PIAA road lamps & high beams.
"Never underestimate the power of a dark CLown!" - Darph Bobo
Old May 15, 2001 | 06:00 PM
spiroh's Avatar
H4,
That looks pretty sweet. I think the black grill would look good on a black car, if the silver shit doesnt show up in the back.
Spiro
RED AEM CAI
Polarg M6 Roadlamps
Old May 15, 2001 | 06:17 PM
H@mmerm@n's Avatar
Thanks, dude. It actually looks better in that picture than any other.
When you look at it from a closer viewpoint the black wing reflects the light and mucks up the whole look. It might help if it was spray painted the same color as the mesh.
Mike
Old May 15, 2001 | 11:14 PM
<font face="Verdana, Arial" size="2">Originally posted by synth19:
g
</font>
This is how it looks like in my car
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 16, 2001 | 03:10 AM
AirC's Avatar
Thanks for all the templates silverknight. Ill be sure to try it tomorrow. Can you take the back black piece off completely so nothing will be showing? Also can you please give me some tips on how i can secure the grille as far as putting it on the bottom bumper. I want to coverup the very botttom of the bumper but no clue how to make the grille secured. Is it better to cut the grille to the exact hsape of the whole or to place it and bend it in? ANy suggestions would help. Thanks alot.
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Diamond Nicrome Limo Mirror Tint
Undetectable K40 w/t Diffuser
Kicker 12" Competition
Cleared Headlights
Custom Int/Ext Lights
Comptech Sway Bars
AEM CAI w/t Bypass Valve
Eibach Pro Kit
Denso Iridium Spark Plugs
Old May 16, 2001 | 07:47 AM
KavexTrax's Avatar
<font face="Verdana, Arial" size="2">Originally posted by H4mm3rm4n:
</font>
Yah, the chain mail look similar to the IS300
grill makes it look flimsy, not a really solid and "built" feel to it.
- Kvit -
Other
• [DVD List]
• [Southern Calif. Nite Meet 5/17: Tustin Black Angus 6-7pm]
Old May 16, 2001 | 08:23 AM
Aysle's Avatar
Anyone know of a place I can buy this stuff online? I checked at all the local Home Depots but they don't have the stuff. Don't really need gutter guards in SoCal.
01 CL-S Navi - Black/Ebony
Xephyr CAI
Alpine MRV-1507 V12 Amp - Tested @ 1,237 Watts RMS - 2,078 Watts Max
2x Alpine 12" Type R - Custom Enclosure
Escort Passport 8500
Old May 16, 2001 | 09:47 AM
eclipse23's Avatar
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by spiroh:
H4,
Spiro
</font>
You can remove that silver piece, I did.
01' Acura CL Type-S
Piaa 19169 Bulbs
CompTech Exhaust
Old May 16, 2001 | 10:48 AM
<font face="Verdana, Arial" size="2">Originally posted by AirC:
</font>
The black center piece is part of the whole piece. If you have the gut, hack saw it out. If you really do it, you should use the thicker mesh so it can stay firmer. Also it need to be strong to hold the Acura emblem if you wanna put it on. I would check with the dealer or junkyard to buy a reserve grill before hacksaw it out.
About the bottom of the bumper, same thing, use the thicker mesh, because the one that I use, it's too thin. Good luck.
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 16, 2001 | 05:40 PM
AirC's Avatar
SilverKnight, how did you get it to fit with one piece. Im down the the last setp to just cut out the mesh to fit it perfectly, but the 6 inches is not tall enough since the thing is curved. I can get either one side and the middle covered, but not the other side. or i can just not have the middel covered fully. Im using hte exactly materials you have posted...
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
Old May 16, 2001 | 05:48 PM
eclipse23's Avatar
Moderator Alumnus
</font>
I HAD THE SAME PROBLEM, STRETCH IT BABY !!!!!!
01' Acura CL Type-S
Piaa 19169 Bulbs
CompTech Exhaust
Really Cool Mesh Grill
Old May 16, 2001 | 05:49 PM
AirC's Avatar
I tried using the acura sign to secure it too and the dont even fit through the holes. i endedup just juamming it through and now its borken in the middle but i could care less right now about that...got any tips on how to physically make it fit since 6 inches isnt enough? or did you actually do it in 2 pieces?thanks alot
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
Old May 16, 2001 | 05:52 PM
eclipse23's Avatar
Moderator Alumnus
</font>
DUDE!
Just snip two holes out for the Acura sign Jeesh your rough!
Now try to fit it best and stretch out the wire using a tool or something like pliars. I got it to fit barely but it fits!
01' Acura CL Type-S
Piaa 19169 Bulbs
CompTech Exhaust
Old May 16, 2001 | 06:13 PM
</font>
Just be careful with the Acura symbol, cut one or two wires of the mesh if neccessary.
About the width of the mesh, pull and stretch it. I did mine with just 1 piece.
Be careful though, the edge is sharp, dont cut yourself.
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 16, 2001 | 06:54 PM
AirC's Avatar
Thanks so much for the help Eclipse and SIlverknight. I was just fustrated at it. I think i finally got hte top part done. The bottom has a tiny hole cuz it wasnt long enough but its good enough. Thanks again for all the help. Its greatly appreciated. Now its time to try the bottom part. Now thats going to be rough. THanks.
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
Old May 16, 2001 | 07:02 PM
AirC's Avatar
Do you guys think i need that foam piece that goes on the the chrome covering? I forgot to put it back in when i installed everything back. I dont particularly want to take it apart again...ANyone know know what it does or if its necessary? THanks everyone.
01' CL 3.2 Premium.
Tan/Black
Neuspeed Strut Bar
Cleared Headlights
Comptech Sway Bars
Eibach Pro Kit
Old May 16, 2001 | 08:09 PM
</font>
do you want one more source for the infamous rattling music? if yes, don't bother to put the foam piece back in
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
Old May 16, 2001 | 09:46 PM
crrink's Avatar
Looks very cool....but does anyone know if any aftermarket manufacturer plans on making a similar grill for our cars?
I'd prefer to buy one and bolt it on than to get out the wire cutters and other tools :-)
Old May 16, 2001 | 11:11 PM
<font face="Verdana, Arial" size="2">Originally posted by crrink:
</font>
Elipse ... May be you and I should start this business. Charge customers $35/piece. We'll be rich
'01 Silver CL-S
Painted Mud Guard
(modified) CAI.
My Car
m_rgaan
Sep 1, 2015 08:30 PM
Fuchfaccio
Aug 2, 2015 11:56 AM
kenny416
Feb 25, 2012 07:15 AM
SilverKnight
2G CL Frequently Asked Questions
May 15, 2001 01:13 AM
