HELP!!! Wheel shaking at 55!
Old Oct 29, 2008 | 04:25 PM
CL-Slick's Avatar
Chillin' in my trailer
Exclamation HELP!!! Wheel shaking at 55!
I recently did front brakes on my CL. Now when I reach 55mph my wheels shake like crazy. They didn't do this before, and the wheels were recently balanced.
Old Oct 29, 2008 | 04:32 PM
immauser's Avatar
Registered Abuser
wow..it shakes when ur driving and not even breaking??
Old Oct 29, 2008 | 04:49 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
swap the wheels around and see if that changes anything. maybe you didn't seat the brakes on right as well when you did them
Old Oct 29, 2008 | 05:21 PM
fuzzy02CLS's Avatar
stock rims?
nspec_ya4's Avatar
Regional Coordinator (Texas)
is it continuous at 55? or only some times?
if continuous, then u should rebalance them. may be a weight fell off.
Old Oct 29, 2008 | 09:03 PM
CL-Slick's Avatar
I think I figured out the problem. I put on new pads and didn't turn the rotors (they are slightly warped). I think that is causing the shaking.
Old Oct 29, 2008 | 09:20 PM
'01White3.2CL's Avatar
TellinItLikeItIsSince1/06
could be a bent rim. i ahd this problem and i didnt notice until i bought new rims and noticed one of my front rims was bent on the inside which was not noticable until you take it off and see a tiny bend which caused huge shaking
if it comes back, check the inside edge of your rims.
Old Oct 30, 2008 | 08:19 AM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
this happen to me but only in the frigid winter when there is snow on the ground and ice got up under the car and in the wheels cuase the car to shake...
Old Oct 30, 2008 | 09:16 AM
GRNMCHN03cl's Avatar
You did not resurface your rotors when you replaced your pads? Shame on you. This could explane the shaking. As you might know, the pad pretty much touches the surface of the rotors at all times. If you have an uneven surface(most likely on an old rot it could cause the shaking you have said.
Old Oct 30, 2008 | 10:26 AM
CL-Slick's Avatar
Going to get the rotos truned after work.
Old Oct 30, 2008 | 10:40 AM
Sweet..hopefully the pads did not get too gauged from the rotors. Good luck bro.
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
redsox68
Sep 16, 2015 06:18 PM
MikeYutkin
Sep 10, 2015 10:13 PM
