help running amp to stock bose
6mt swapped..smart
Looked in the audio and video faq section already, but just a simple question I would like to run by you guys. What is the easiest way to run rca's for an aftermarket amplifer. I want to run a sub, and was wondering if I could buy an adaptor that would use the stock amp's rca connections or if there was an unused rca output somewhere in the back of the bose head unit for scenerios like these. I know it's probably here somewhere, but I couldn't find much. Thanks guys.
Originally Posted by gaping46and2
There's no RCA outputs on the headunit. you'd have to tap into the wires at the connection to the amp in the trunk. The wiring is somewhere in the A/V section, just have to search for it.
https://acurazine.com/forums/audio-video-electronics-navigation-22/
Someone over there should be able to help you out...
mada51589
05-03-2022 08:54 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
handsom-hustla
11-13-2015 05:04 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
yahelou
09-06-2015 09:12 PM
