HELP PICS /INFO? how do u clean the IAC valve (intake air control) vavle
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
anybody got pics a DIY i got the same problem every ones got except 4 i am not superchrgd, but i use a k and n filter (could be the cause) //ruff idle and sometimes stall mostly after hard driving//
anybody got pics or post or DIY for how to clean the IAC of a cl type s.
help help
help help
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Former Sponsor
Take off your intake on the throttle body side. Start your vehicle and reach underneat the plastic guard and pull the throttle cable to rev up your car. This will cause the inner flap to open up and air to be sucked in. As you're doing this shoot some air intake cleaner in so that it will be sucked in and eventually get into your IACV to clean it out.
Josh
Excelerate LLC
Josh
Excelerate LLC
Josh
Excelerate LLC
Josh
Excelerate LLC
thanks i read u earlier post , i just did this after which the car decided to throw a fukin code, (now the check engine light was on) i will see how this holds up. might take it in 4 the 4th time 4 the same problem.
cycdaniel
12-17-2019 10:58 AM
Abe_Froman
09-16-2015 01:27 PM
