Help, need schematic to stock deck
Guys,
I need the schematic for the stock deck wiring. I need to know which wire is for the dimmer, and the power antenna.
Thanks,
Spiro
Thanks,
Spiro
Usually aftermarket decks only have one wire for dimmer. Which one of these wires would you use?
Originally Posted by rbf351
i could have told you the dimmer wire is the red and red/black wires
just a fyi, all honda/acura's dimmer/interior lighting wires are this color
Registered User
Thanks. Hopefully I can figure out my problems with the deck.
you would use the red with black stripe wire, which is +12V, which means it won't work off the dimmer, but will illuminate when you turn your head lights on
rboller
09-23-2015 02:49 PM
