HELP ne1 with audio knowledge
Old Aug 17, 2003 | 10:31 PM
green972.2's Avatar
Hey i just bought a sony cdx m800 head unit... it puts out 23.2 watts RMS x 4. Now I've herd that this fries the stock power wiring... if so what do I do to power this head unit?
Old Aug 18, 2003 | 07:40 AM
Bill Faure's Avatar
Re: HELP ne1 with audio knowledge
By Degree I am a Electrical Engineer. I can tell you that 23.2 watts RMS x 4 will not fry any automotive wiring. Unless you for what ever reason have 32 AWG magnet wire in your car.
Old Aug 18, 2003 | 08:09 AM
BEETROOT's Avatar
Yeehaw
if you have the bose stock speakers that sony wont work without an adapter, and even then it will probably sound bad. bose = 2 ohms, sony = 4 ohms
Old Aug 18, 2003 | 07:47 PM
AztecRol's Avatar
The Screeching Toyo's
Re: Re: HELP ne1 with audio knowledge
32 AWG magnet wire!!!
Old Aug 18, 2003 | 07:53 PM
AztecRol's Avatar
You are right about needing an adaptor Beetroot, but...
Actually the problem is that the BOSE system uses its own amp for the speakers. And the amp is not true line level like 99.9% of the amps in the car audio world!!! The adaptor will make take that mismatch, and correct it. The amp is in the trunk behind the passenger side trim panel.
Old Aug 18, 2003 | 08:53 PM
green972.2's Avatar
thanks... no bose in my car though.... a local audio install expert told me today that no new wiring is needed unless i wanted to add amps... is this true?
Old Aug 18, 2003 | 10:06 PM
AztecRol's Avatar
YES
Old Aug 18, 2003 | 10:43 PM
BEETROOT's Avatar
Yeehaw
hey aztec- I thought the problem with the bose was the whole system ran 2 ohms, so if you install a new deck it wouldnt power the speakers correctly. assuming the deck is 4 ohm and you bypass the factory amp, what would it matter if the factory amp is line level or not if you didn't use it?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
