help! my car wont shift from P ..!!!
this morning when i started my car i noticed i cant shift from P to D, the shifter would just stuck in P. What is worng with my car??
thanks for any help
thanks for any help
Check if your brake lights work when you step on the brake pedal. If they don't, check if your front power outlet (cig ltr hole) has power. If it does, then the brake switch is probably bad- if it dosen't, check the acc fuses. The most common faults are blown fuses or bad brake light switches.
