Help me ODB2 COde P1259 P1739 P1740
Old 09-17-2011, 08:01 PM
99TLhot's Avatar
Unhappy Help me ODB2 COde P1259 P1739 P1740
Can anyone help me what is this mean? Should i replace the pressure switches ? I noted when driving today the check engine come on on the VSA and the TCS light come one at the same time , try to get on the hight way the car rpm gauge pounce around 3500 rmp.... what the fuck is happen to my CAR? please help
Old 09-17-2011, 11:17 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
transmission is 95% donezo bro.. sorry to say.. that's what happend to my car right after i got it at 96000kms . all 3 lights came on simultaneously.
is ur trans acting weird at all... it must..
u in the GTA or.. usa?
Old 09-18-2011, 04:39 PM
99TLhot's Avatar
lil bit car still driving but wonder if i should replace the 3rd and 4th presure switch or not?
99TLhot's Avatar
us and the car only had 70k
Old 09-18-2011, 06:01 PM
o1s
o1s's Avatar
not necessarily. mine threw strange codes randomly for years before the tranny finally went out. the tps would cause all of those lights to come on as well.
Old 09-18-2011, 07:27 PM
it wouldn't cause all those code to be shat out.
Old 09-18-2011, 08:27 PM
o1s
o1s's Avatar
i had small random things that threw 5-8 codes a piece. unhook the battery and hold the brake pedal down for a few seconds. it will reset the ecu. then see if it throws the codes again. little glitches will cause the ecu to throw random codes sometimes.
Old 09-18-2011, 09:34 PM
99TLhot's Avatar
when is on the car at the light or idle it just wanna stall is this happen to any of you guy? and i should replace the 3rd and 4th clutch pressure sensor or not?
Old 09-18-2011, 10:11 PM
those pressure sensors rarely fail.. if anything just need to be cleaned..
well if it isn't the trans then look at the tps or something in that area
Jamus22
06-11-2023 10:08 AM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
mars
09-28-2015 11:03 AM
Quick Reply: Help me ODB2 COde P1259 P1739 P1740
