Help how do you run wire from obdII connector to fusebox
Okay, Im gonna need some help. If would be great help if someone w/ a helm manual or if anyone who installed the v1 remote display inbetween the seatwarmers buttons. (infront of obdII connector)
Im trying to connect my smart cord direct wire(something like the v1 remote display) in inbetween the seatwarmer button. But i'v been trying everything and can't get the wire from the obd connection place to the back where i can run cord to the fuse box.
I tried first w/ a coat hanger just to see if I can get it through all way, then i just going to tie a string or the wire and then feed it through. but im having difficulties.
Also how do you take the 'not an anstray' thing out?
thanx a bunch
thanx a bunch
the coat hander method shouldnt be used when feeding a wire through the dash...you might pull out a harness
you should remove the side panel. it'll take you 2 seconds to feed the wire through after you remove it
take off the wood trim, pull back the center console, then youll be able to take off the side center console panel
Originally posted by typeR:
<STRONG>hey nova sorry dont have the answer to your question but im workin on a photo shop project and could use a hi res side view of a white cl-S</STRONG>
that's the link of my car and jz's car from lastyear.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
cak165
1G TSX Problems & Fixes
Sep 2, 2015 09:21 AM
