Help: How to change reverse bulbs for 2003 CL?
Old Oct 23, 2002 | 01:45 PM
6spdmanual's Avatar
Just bought PIAA (PIA-19225) xtreme white bulbs. I disconnected the plug, but can't pulled the bulb out from the socket. Anybody can teach me how to install it???
Thanks!!
Old Oct 23, 2002 | 01:56 PM
6speedS's Avatar
Quicksilver
It should be in the manual,the same as the headlights i believe
Old Oct 23, 2002 | 02:49 PM
JasonT's Avatar
You twist the socket out of the housing. This lets you pull the light out. Then just pull the bulb out, push the new one in, & re install. Easy!
Old Oct 23, 2002 | 02:51 PM
Jbusiness's Avatar
2001 Black CL-S
Yeah, peep the owner's manual...
easy though, 4 plastic screws...remove plastic over carpet...peel back carpet...change bulb.
Old Oct 23, 2002 | 03:08 PM
6spdmanual's Avatar
I've got it thank you!
Old Oct 23, 2002 | 03:20 PM
juniorbean's Avatar
Is it just me or are those wedge bulbs? It sounds like you guys are explaining some type of socket bulbs which twist.. however, the wedge bulbs generally just pop in and out. Is that the right bulb??
juniorbean's Avatar
OK, nevermind
rockyboy
Aug 4, 2024 10:35 AM
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
Aleax
Sep 11, 2015 11:31 AM
Mcj270
Aug 31, 2015 04:45 PM
