help help For those who have tested the legend/nsx brake swap
"IF ONE WERE GOING THE LEGEND CALIPER ROUTE, WHAT ROTORS WOULD U RECOMMEND, I AM TRYING TO AVOID THE STOCK ROTORS, AND WHAT PADS is recommended with minimum or no noise and brake dust"
or could i use the stock pads 4 EXAMPLE": racing brake HP rotors (on Groupbuy rgt now!!!) HAWK HPS BRAKe PADS AND GOODRIDGE STAINLESS BRAKE LINES!!!!!! sb said smth abt getting ebc pads. pls help!!! objectives are 1. No noise as i was told slotted/drilled seem to make more noise than the pln rotors. 2. lesss or no brake dust. |
My Rotora slotted don't make any noise at all... I doubt that just from switching to Legend calipers would all of a sudden make a difference in sound...
i.e legend calipers, racing brake hp rotors, hawk hps pads i just wanted a rotor and brake combo that will avoid brake dust and noise. |
i used the legend coupe calipers because the have the biggest pistons, the brembo rotor blanks and the aem brake pads. they work great a lot better stopping, no dust, no noise and no warping yet. the most important thing is to bed the pads in correctly or they will not work right here check out my install pics and review http://www.acura-cl.com/forums/showt...highlight=pads
rotora slotted blanks and NAPA CERAMIX pads no noise no dust
well said , thanks for the help.
civicking
one MORE quESTION :wish: DO I USE AFTERMARKET PADS AND ROTORS WITH THE 2ND GENRATION(01-03) SPECS OR I HAVE TO USE THE SPECS FOR A 95 ACURA LEGEND COUPE LS (93-95) i.e if i am looking to get rotora's slotted on the website do i use a 95 legend as my search for the part # or do i use a 01 cl type s. i thought all we needed from the legend was the caliper that is it. (not sure though) |
I believe they are the same.
thanks,,
youall |
whats the same?
The pads for the Legend and the CL?
