View Poll Results: Which rims?
Maya STM / STU - 19" Black Chrome w/ chrome lip
18
75.00%
Axis Wheel Site Mesh II - 19" Polish w/ Chrome lip
25.00%
Voters: 24. You may not vote on this poll
help a brotha out!!!
The axis look cool as hell, there is someone in the gallery with a black car with those on there. These are the rims i am planning on getting once i get the $$$ together. Once i saw those on his car in the pics i was sold!!
The price difference between the two wheels are big. I would go with the STU's. I believe the Maya wheels are made by Trafficstar in Japan. You should send msg to XkraziX as he had a friend who was trying to sell a set of 19X8 STU's. Also, price out a set of the Trafficstar Mesh II as they maybe cheaper than the Maya. Post pics on whatever you decide on!! Good luck.
Originally posted by nokio
i can get hookups on both, only a 300$ difference
also, will 225/45 (or 235/45 not sure ) wheels/tires rub any?
Thanks.
ok, so what does the second number mean??? our cars stocks say 50
_____________________________________
liquid_x: says;
215 is the width of the tire in mm i think
You are correct
To be technically correct it is called the "Section Width" and is measured in millimeters. Section Width is the distance between the sidewalls. Oh yeah, it depends somewhat on the width of the rim the tire is installed on.
liquid_x: says;
You are correct
. To be technically correct it is called the "Section Width" and is measured in millimeters. Section Width is the distance between the sidewalls. Oh yeah, it depends somewhat on the width of the rim the tire is installed on.
Tough choice, but I think I'd go with the Mayas.
Exactly, 235/35/19 would keep you close to stock. 245/35/19 may work, depending on the wheels' offset, but I don't think anyone on here has gone with that size yet so you'd be the guinea pig.
Originally posted by danny25
on 19x8, yeah 235 would work, you could go wider if you wanted too. To stay closest to stock diameter, you'd want 235/35/19s. That should be almost exactly the same.
Ron Burgundy
AcuraZine's Hall of Fame
507
Jul 6, 2006 03:01 PM
