help
Old Oct 12, 2010 | 07:24 PM
sethjm1983's Avatar
3rd Gear
help
have a 01 acura cl with codes po300 po001 thru po006 with 1399 need help
Old Oct 12, 2010 | 07:29 PM
sethjm1983's Avatar
3rd Gear
replaced plugs with ngk, cleaned injectors, cleaned egr, tryed swaping coils with one new coil around the engine still missing
Old Oct 12, 2010 | 07:30 PM
FiftyFive's Avatar
Moderator Alumnus
I'll direct this to the Acura CL section, hopefully someone will be able to help you over there.
Old Oct 12, 2010 | 08:48 PM
ggesq's Avatar
seth- welcome to the forums. Please do not start duplicate threads in various areas of the forums. The duplicate threads you have created have been deleted. Good luck with resolving your issue. Thanks.
Old Oct 13, 2010 | 09:20 AM
Rajca's Avatar
wham bam thank you ma'am
Injectors. I had a bad one in my tl and it drove me crazy for months trying to find the problem. Almost tore the block apart
Old Oct 24, 2010 | 01:41 AM
Stanley87's Avatar
You have any luck Seth?? Mine just started throwing the same codes and its driving me crazy. Is yours lighting up the check engine, VSA and (!) light too?
Old Oct 24, 2010 | 01:44 AM
Stanley87's Avatar
Rajca, I was planning on sending you a PM but being as I have been on the forums in a very long time they kicked me back to noob statues haha. Was yours having the same warning lights/error codes? How did you get to injectors (meaning, what did you do first)? Did you do the EGR valve clean out?
Old Oct 24, 2010 | 07:54 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
would injector cleaner or sea foam or zmax help clean the injectors out..?? could save you some time and money.
i'd at least give it a shot
Old Oct 24, 2010 | 10:13 AM
Rajca's Avatar
i cleaned the egr ports, changed the egr, fuel pressure regulator ect..
then i had injectors and a fuel rail from one of my spare engine and just swapped over all the injectors. still had a minor misfire from time to time only on one cyl this time. turns out that one of those injectors was also bad. so i had another spare laying around (ive got lots and lots of spare parts) and all was good.
Old Oct 24, 2010 | 08:26 PM
Stanley87's Avatar
Got any extra injectors you want to part with then? :-) Its starting to drive me crazy.
Old Oct 25, 2010 | 05:02 AM
Rajca's Avatar
not at the moment. i threw the 6 from my tl in the trash.
