Help!!!
Old Jun 3, 2003 | 03:38 AM
anj2's Avatar
That's hot...
Help!!!
I was putting my seat foward and heard a pop from the right speakers. Now all my right speakers do not work. The left speakers still work but no sound from the right. My subs won't work either.
Can anyone explain to me what the problem could be? Could the stock amp be fried or maybe my speakers might be blown?
The popping and the cutting out of the right speakers had happened before when I moved the seat foward, but the speakers came back on when I moved the seat foward. But they didn't come on this time.
I've had the JL ProWedge 10W3 with a JL 250/1 amp in my car for about a year now and have had no problems until now...
Someone please help...Thanks
Old Jun 3, 2003 | 09:11 AM
Doc.Booty's Avatar
Check your fuses first.
Old Jun 3, 2003 | 04:11 PM
anj2's Avatar
That's hot...
Which fuse should I be looking at, because the radio is still working. I checked the fuse list and only saw one dealing with the radio.
Since it happened as the seat was moving foward, is there anything else I should be looking at?
Old Jun 3, 2003 | 04:33 PM
Doc.Booty's Avatar
No clue.
Could your seat have been moving over any wiring dealing with your system?
Old Jun 3, 2003 | 08:32 PM
icy CL's Avatar
the power wire for your subs, if the installer did run a new power wire from the battery, is most likely on the driver's side. while moving your seat, something may have moved the power wire...maybe it got crunched or touched something and blew your amps. do the amps have power to them?
