Heavy rain/flooding tomorrow, disconnect CAI pipe?
hey guys, there is very heavy rain expected for north carolina tomorrow, with most likely flooding b/c everything is soaked from the snow last weekend. i have a AEM CAI without a bypass valve. i remember a mechanic friend a long time ago, saying if you need to travel through water without a bypass valve, open your hood up and disconnect the pipe from the engine. it's okay for the engine to run without the filter for a day than water in it.
is that all i need to do? do i need to move the pipe away from the engine intake? there is not much room in there. but as long as i disconnect it and there is no seal around it, it shouldn't suck in air from the AEM filter, right? i do not have time to do other things for tomorrow. thanks for the help guys
Be Strong AND Courageous!
If I am not mistaken, the air is "sucked" thru the pipe to the engine via positive pressure, but to be on th safe side, I would put a plastic bag secured very well with a heavy rubber band or some duct tape around the connector to keep any splashes that might come up the CAI, away from the throttle body... remember, a large splash under the hood could also send water into the TB, so be really careful out there....
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Bypass valve ftw!
B A N N E D
x???, with you should never be driving through water that deep to ever get the airfilter soaked
or you get this happening to your car instead![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
https://acurazine.com/forums/showthr...ht=socal+flood
happy
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
3.7L Nitrous Breathing CL
Only cause I haven't put the inner fenders on and I dont want to trash the new filter only.
I still would not worry about sucking in water.
If you have the inner fenders on then It will be fine unless you like driving in over a foot water.
You can pull the pipe if your concernd.
I had my off for 2 days but as soon as the engine gets hot the car loses noticable power.
thanks for the replies guys. driving in the rainstorm with 2 inches of rain went well.
i don't have a bypass valve, that's why i was asking that question. and no, i was not talking about water that comes up all the way over the bumper and you need a Jeep to go through. but cars with CAI without a bypass valve, cannot go through any water at all, whereas stock camrys, civics, prius are all passing by you through the water. I'm talking about the usual places where water collects with poor drainage (near underpasses, bridges, ditches, etc)
B A N N E D
the bumper/wheelwell liner actually do a pretty damn good job of shielding the CAI from any splashes of water (you might get some on the CAI, but nothing even close to worrying about) so really the only time is when the water is deep enough to actually start submergeing the bumper, even then it would have to be like half way up the bumper to really start to get the whole filter wet (the air will just flow through the dryer part of the filter) and be at that height, you would start to get water into the doors anyways
not really. i was in my friend's 2001 CL-S, he drove through some water that was right below bumper height and we got stuck, engine shut up, hydrolocked. he had no bypass valve. while all the other cars slowly went around us and had no problem, including "small" cars like ford focuses, etc. A CAI without a bypass valve will allow you to do almost nothing. that's why i was asking this, and disconnected the pipe as a precautionary measure.
Also you obviously havent seen or read the other intake threads where i posted this
https://acurazine.com/forums/2g-cl-2001-2003-50/cl-s-cold-air-intake-762082/
http://www.youtube.com/watch?v=wvqc6wcng_g
wham bam thank you ma'am
some things that ppl dont know is that the ice box velocity stack sits almost as low as a cai filter. BUT, BUT, the ice box has a small opening on the side of the box by the fender with a rubber flap on the inside that acts as s bypass valve. Genius idea, some smart thinking.
It should not have not even come close to hydrolocking the motor with water just below the filter. You would have to submerge it. Getting wet wont do it. Also the Bypass valve is a joke and has caused more issues than good for many.
How many times do we need to tell you? The TL and CL are the same car minus 2 doors. My filter was bone dry. You WONT Hydrolock the motor from puddles splashing up (unless you are dumb enough to be driving around without fender liners and the lower splash shield your filter wont get wet). You DONT get it. Its not the CL or any car, it doesnt matter. Rain wont do it. You have to submerge the filter in water to do so. IF you are driving thru that much water in the first place you deserve to have a blown motor.
B A N N E D
![Victory](https://acurazine.com/forums/images/smilies/victory.gif)
It rains harder & faster & more in south FL for 3 months straight.
Well, who's gonna be using a bypass valve when the AEM website says its not to be used with forced induction LOL. So if your thinkin about gettin that Comptech Supercharger, don't worry about it lol.
But I heard the only way you can cause damage is if you completely submerge the filter AND you fully throttle it to have the air being sucked in. So even if you drive thru a puddle, take your foot off the gas.
B A N N E D
and more then likely the motor will stall out before hydrolocking, unless of course you go real deep real fast, but then the car is proably already jacked by then though
ExcelerateRep
10-14-2015 08:20 AM
