Headlight help...
Old Nov 13, 2008 | 10:18 AM
CL-Slick's Avatar
Chillin' in my trailer
Exclamation Headlight help...
I have been having problems with my driver's side headlight lately. Yesterday I discovered it wasn't working so I tuned them on and off rapidly a few times and it worked. This morning It wasn't on so I did the same thing and it came back on, but eventually went out again. I am unfimiliar with these type of lights. What is the problem, what parts will I need, and how much will it cost? Thanks in avance.
Old Nov 13, 2008 | 10:41 AM
Excelerate's Avatar
Former Sponsor
Switch your bulbs to see if it's the bulbs. If both aren't coming on it's likely an electrical issue or a ballast.
Old Nov 13, 2008 | 11:01 AM
CL-Slick's Avatar
Thanks man, is there a DIY on this?
Old Nov 13, 2008 | 10:37 PM
CL-Slick's Avatar
My dad and I are going to switch out the bulbs this weekend to determine the problem. I think I am going to get some 8000K bulbs off of Ebay. I can get a set for about $70.
Old Nov 13, 2008 | 11:08 PM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
https://acurazine.com/forums/showthr...ht=ballast+diy
check out post #5. could be the ballast as well.
Old Nov 14, 2008 | 10:21 AM
CL-Slick's Avatar
Thanks man. I hope it's just the bulb.
Old Nov 14, 2008 | 10:25 AM
DoubleSh0t's Avatar
FYI rapidly turning your lights on/off is bad for your lights. When my alarm went off (headlights flash on/off) with my Plug and Play HID kit, it actually shorted the ballast out.
Old Nov 14, 2008 | 12:54 PM
gnuts's Avatar
3.5 psi
swap the bulbs you have now before going ahead and buying new bulbs...unless you want them anyways. Check the fuse to the headlight also. If it's not either of those then it's your ballast/inverter. I've replaced both of mine in the last year. It's an easy DIY.
Old Nov 14, 2008 | 04:33 PM
CL-Slick's Avatar
Thanks for the help. I have to go buy the torx-bit tool and I'll try changing out the bulbs tomorrow.
Old Nov 15, 2008 | 07:58 AM
djarovsky's Avatar
This TSB may also help:
http://www.in.honda.com/Rjanisis/pubs/SB/B08-044.PDF
Old Nov 15, 2008 | 09:09 AM
CL-Slick's Avatar
Thanks man, I'm going to try and figure out the problem when I get off of work.
Old Nov 15, 2008 | 09:53 AM
Onese1f's Avatar
Is a chargin mah lazar in
Yeah I have the EXACT same problem..i was driving home from a friends house last night and my drivers side light just decided to go out. No flickering, no color change, just a cut off. This morning I popped the hood and checked the fuses and they were all good. I'm moving on to grounding wires but I fear for the worst...although that sparks a question. (excuse the pun) If no fuses blew, would that be indicative of a bad ballast, or simply a short somewhere?
At least this is a good excuse for me to switch to aftermarket bulbs/ballasts, not that I wanted to but imo aftermarket kit > stock inverter..Going down to work on the car, I'll post up what I find.
Old Nov 16, 2008 | 06:12 PM
CL-Slick's Avatar
I officially have a bad ballast. Anyone know where to get a cheap one?
Old Nov 17, 2008 | 06:56 AM
gnuts's Avatar
3.5 psi
acura of peoria is fairly cheap, fast delivery. (for oem parts) http://www.oemacuraparts.com/partloc...?siteid=214055
Some ppl have used after market kits too. Lots of info on this, if you search. There's also a DIY.
Old Nov 17, 2008 | 10:57 AM
CL-Slick's Avatar
I've searched and havn't found anything to really help me out. I am calling the stealership and local Honda shops to get prices.
Old Nov 17, 2008 | 12:51 PM
Onese1f's Avatar
You might want to try ebay..I found a ballast on there for about $140 but got outbid. There is another site that has $55 aftermarket ballasts.
http://www.fashtek.com/?gclid=CPqVmd...FQJHxwodKib-_w
I don't know how legit they are, so I'm also a little skeptical.
In other news, got a $91 fix-it ticket from a cop in the keys.
Finding an OEM ballast is proving to be more of a PITA than it's worth imo.
I'll either be hitting up Akinaboy or Hiddepot later on today to end this damn problem.
Old Nov 17, 2008 | 09:40 PM
CL-Slick's Avatar
I'm going to be hitting up the local salvage yards for the part, then take it to me local honda shop to have it installed.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
