headlight clearing dilema pt II
Old Mar 25, 2002 | 01:46 PM
digitalgm's Avatar
"v1 saved my ass ......."
Peeps, thanks for your help so far with clearing my headlights. During this process I came to the part in the directions where I need to heat up the silicone on the seams of the light. My only question in this process is where? There is a black piece with tabs going on the back of the housing. Do I heat through this? I would imagine so because it seems as if the silicone is sticking to it.... thanks
AdamR
Old Mar 25, 2002 | 04:57 PM
sidemarker's Avatar
i think the best way to prevent leaks is to completely remove the old adhesive stuff and clean all the edges and re-seal it good with the silicon. let it dry for about a day and you should have a good sealed cleared headlamp
realisticly they are going to leak cause they always do. its hard to put a good seal on them
but just cross your finger and if after a year and no condensation, well then you did a great job
sidemarker
Old Mar 25, 2002 | 05:12 PM
4pumpedCL's Avatar
Honkey
Re: headlight clearing dilema pt II
AdamR
You have assumed correctly. Make sure you are gentle with those tabs, I mangled mine. Just take your time, and be careful not to get any of the goo on the backside of the chrome housing. If you try and peel it up you'll take the chrome finish along with it. Good luck
Old Mar 25, 2002 | 06:18 PM
digitalgm's Avatar
well, I have officially mangled my tabs but is that a big deal?
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
jmaxima03
Sep 27, 2015 10:22 AM
