Headlight cleaning
Baller of Uni
Headlight cleaning
So my headlights SUCK. Like they are really foggy, and I have no idea what's good for making them look amazing until I can afford to get some new ones (probably 03 units). What's the best way to go about doing this?
CLkid187 (09-14-2011)
I have found those kits to generally be ok for a short time & then it comes back. I recommend replacement. I tried these kits on my CL, a 02 mustang, a 98 corolla, & 93 explorer. None of them lasted more then 6 months in the FL sun. I even paid a pro shop that does headlight restoration on the mustang once & that was a waste too.
Whats up with RDX owners?
Wet sand and polish them. Make sure you seal them with a quality sealant every few months. Treat them like you would the painted surface of the car.
The problem is the UV coat on them has worn off, causing them to "fog" up.
Baller of Uni
So I ended up using this Meguiar's heavy duty headlight stuff, works damn well. I highly recommend it.
![](http://www.meguiarsdirect.com/imagesEdp/p135894b.jpg)
So the driver's side is done and the passenger is not for a nice comparison
![](http://i55.tinypic.com/14t2bmq.jpg)
Close up of driver side.
![](http://i51.tinypic.com/fp9t0m.jpg)
Close up of passenger side.
![](http://i51.tinypic.com/346u9as.jpg)
anyone tried the sylvania ones? it comes with a clear coat.. wondering if its easy to use.. comes with lifetime warranty on the product.. sounds good i might try this one out
http://www.sylvania.com/ConsumerProd...estorationKit/
damn, those modded headlights with all the chrom corner out, look great, i need to do that too.
ive just used 800grit, then 1500grit, and then 2000grit sandpaper, then a compound, then a heavy wax to do mine, but i have to re-wax every month or so
AmplifiedDetails
09-24-2015 02:55 PM
