Header Questions
Old Mar 27, 2007 | 12:15 PM
aznboi2424's Avatar
Header Questions
Hey guys, just looking at the headers that so many of you have loved, the XS headers.
1. how much was the install?
2. will they fit 3.2 CL type S?
3.is it true that additional power only comes from 4000 rpm+?
4. any noticable or actual power gains?
5. how does it affect MPG?
thanks for answering these guys!
Old Mar 27, 2007 | 12:29 PM
ms_cls's Avatar
Only CL in town!
1. around $300-$400
2. yes they will
3. not really sure about this, but i feel gains throughout, probably more noticable after 4000rpms
4. the gains are noticable
5. about 1mpg more, at first its less because of how they sound and feel since i was pushing the pedal to the floor alot
i hope this helps
Old Mar 27, 2007 | 12:51 PM
RaviNJCLs's Avatar
Originally Posted by ms_cls
1. around $300-$400
2. yes they will
i hope this helps
You got ripped.
I would say between $100-$200 for the install.
You definately feel the gains.
Old Mar 27, 2007 | 01:30 PM
fuzzy02CLS's Avatar
See the FAQ....
https://acurazine.com/forums/showthread.php?p=2539666
Old Mar 27, 2007 | 02:51 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Originally Posted by RaviNJCLs
You got ripped.
Install should run somewhere ~$200 (+/-$50), depending on which shop you take it to.
Old Mar 27, 2007 | 03:01 PM
CL-S 6MT's Avatar
B A N N E D
Sorry to Hijack this thread but i had a couple of quiestions also, this may be benefit others also, when you install these XS headers are there any check engine lights because of 02 sensors, Also i heard people having leaks but if you buy a OEM gasket and better bolts, there will be no leaks nor raspy sounds?, Thanks
Old Mar 27, 2007 | 03:48 PM
There shouldn't be any lights that come up on the dash when installing anything. If there are, then something was either not installed correctly or was broken during the installation. Several members have used the OEM gaskets and replaced the bolts w/o any problems, and others have used the supplied gaskets and bolts also w/o any problems.
Old Mar 27, 2007 | 08:08 PM
Dirty Type-S's Avatar
B A N N E D
i highly suggest new bolts.. but the new gaskets are fine.
Old Mar 28, 2007 | 01:19 AM
aznboi2424's Avatar
when you buy XS headers from ebay, do they come with bolts or gaskets?
200 is not bad, but i will call around for prices.
thanks for answering these questions guys
Old Mar 28, 2007 | 01:44 AM
Yes, the XS Headers come with gaskets and bolts, such as they are.
Old Mar 28, 2007 | 01:52 AM
aznboi2424's Avatar
do these headers fit the auto type s?
is this a DIY or def professional install?
CARB legal for CA ppl?
Old Mar 28, 2007 | 02:25 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
these headers will fit the 3.2 tl cl including the tl/cl-p and the type-s
it is an easy DIY some people have issues with some of the bolts but most people that have really bad problems are up north specially north east. other than some subbern bolts really easy. just takes some times.
its not registared as CARB legal for cali but as long as they dont inspect under the hood for different parts to check for the CARB sticker you should be fine.
Old Mar 30, 2007 | 11:59 AM
MinTS's Avatar
Hey i'm buying the XS headers and planning to do the install myself. If you like I can take pictures, if you would like to attempt the install. Oh by the way, I'm getting the headers for like 150.00 thats including the shipping so if you pay more than 150 for the headers your a sucker.
Old Mar 30, 2007 | 01:09 PM
ironsurfer129's Avatar
CL-Pride
Oh please do include installation pictures, because it will save everyone including me big buck
Old Mar 31, 2007 | 02:06 AM
aznboi2424's Avatar
is it a really easy DIY? approx time to install? do i need to weld anything?
Old Mar 31, 2007 | 08:42 AM
B A N N E D
im most likley doing mine today as well.. ill snap some picz.
Old Mar 31, 2007 | 10:53 AM
LIPPSTUH's Avatar
Unregistered user
i found two DIY from searching on other forums:
1. http://comptechusa.com/store/media/i...ons/ins028.pdf
2.
Tools you’ll need:
~ Jack and 2 Jack stands
~ Torque Wrench
~ 3/8 or ½ drive ratchet
~ 10mm, 12mm, 14mm sockets (and some various others)
~ Open end wrenches (12mm, 14mm)
~ Socket extension(s)
~ Beefy flat head screw driver
~ WD-40
~ A friend
Disconnect your battery. You don’t want the fans to turn on (or any other electrical mayhem going on). You may have your hands near the fan blades – if it kick’s on while your there, plan on a trip to the ER for some stitches. Be safe - DISCONECT YOUR BATTERY!!!
Jack the car up on both sides and secure it by using jack stands. Make certain they are secure because you will be tugging on some bolts and rocking the car a bit. You don’t want 3000 lbs falling on you.
Now remove the electric fan on the passenger side. There are 3 10mm bolts holding it to the radiator, and 3 electrical connections to remove. This will make accessing the manifold nuts much easier.
Remove the heat shields front and back by simply taking out the 3 bolts on each heat shield. Since your right there, go ahead and spray your 5 manifold nuts with WD-40 and let them soak for a bit. You’ll come back to them later.
Climb under your car (bring your open-end wrench, WD-40, and ratchet/sockets) and remove the 02 sensor. Start by tracing the wire back about 6” and disconnect it from the harness FIRST, then remove the sensor at the bung from the a-pipe with the open-ended wrench. DO NOT spray wd-40 near the o2 sensor! While your there, spray down the three bolts at the cat. Let that sit for a while you drink a beer.
Done? Okay, it’s time to get to the REAL work.
Start off with the cat by removing the 3 bolts. They are a real PITA. It’s easiest to do this by first spitting at them and calling them foul names like, $~!@%, &$^*(&, and !!!()%. After you get through verbally punishing them, you will need to use an open-end box-end wrench to help keep the nut on the other side from spinning. (Tip: bang the ratchet with your palm a few times to help break tension). As I’ve said already they are a real PITA, but you can do it. WARNING: do not strip out the bolt heads, you’ll be sorry.
Next up, you’ll need to remove the a-pipe from the manifolds. To do this, you will need an extension, your ratchet, and a 14mm socket. From the underside of the vehicle, remove the three bolts that connect the a-pipe to the manifolds. Do this front and back. It will be difficult to get around the engine mount, but it can be done. If you MUST, use a universal joint to get some flexibility. I don’t suggest you do it because you’ll loose some power to muscle the bolt off. When you get those off, the a-pipe drops right out. SWEET. All that’s left is the 2 manifolds now.
You’ll be removing the nuts for the manifolds from the top side of the engine bay. This part is easy. My nuts came off the manifold without even having to swear at them. It’s sad how ugly and inefficient the old setup was! Relax a second to admire the work you’ve done so far. Drink another beer, and get ready for the grand finish.
On a side note: As much as you’d like to – DO NOT start the car with your manifolds off or with just the new headers on. This will cause problems now with the new setup, and could possibly even bend your valves!
Okay, finish your beer – smash the aluminum can against your forehead, grunt like Tim Allen, and let’s get back to work.
Have a look at your new headers. Determine which header is the front and which is the back. On Comptech the logo is the front one, on OBX and Megan, the logo is the back header. Off brand EBay Headers have no logo – but you can figure it out, one will clear the engine mount, one won’t.
Now that you have determine which is which, put the gasket over the studs on the head, and slip the header over each side. LOOSELY add the 5 nuts back on by hand - make sure you don’t cross thread them.
Once your upper headers are on, the hard part is to try to put the a-pipe on. It helps by using the emergency jack or your buddy to help keep it up in the air. Make sure the put the O-rings on between the headers and a-pipe. Try to line them up and throw the bolts in at the same time. I hope you’re good at multi-tasking. It’s tough to describe it any better than this, and it’s one of the hardest parts: Have your buddy hold new a-pipe up to the new headers. When they are close to being lined up, pop a bolt through and putting a nut on the other side. The washer will go on the NUT side, not at the bolt head, BTW.
Once you get all the bolts through the a-pipe to manifold, you’ll need to connect the a-pipe to the cat. That’s easy because there is a flex tube right before the cat that lets you move it easily. Bolt the a-pipe to the cat and reinstall the 02 sensor – don’t forget to plug it back into the harness, Einstein.
When everything is connected, you can go ahead and start tightening all the bolts. Cat first, then the a-pipe to manifold, then the manifold to the heads. Check everything over and make sure that the engine is clear of everything.
Lower the car and reconnect the battery. Check for stray parts again. If it’s all clear, go ahead and start the car. Let it run for 5 mins and listen for any exhaust leaks. The Header should be a bit louder than the stock manifolds, but not a whole lot. If you have a loud tapping sound it’s an exhaust leak somewhere. You’ll want to re-tighten that immediately before the engine really warms up. Once all stray leaks are taken care of, it’s time to take it for a test spin. Don’t worry – by the time you get to this stage, you’ll be at the 1.5 hour mark and both the beers you drank earlier are worn off by now. Enjoy the feel of a little more torque down low. You’ll notice more and more power for about a week as your ECU learns.
Hope this helped some guys. Sorry I don’t have any pics of it all. I may try to add some later if I get my digi-cam back. I welcome feedback or additions/modifications to my DIY if you have any.
~ Timmy
^ I took from the [dot]net forum from member Timmybighands. this was done on a 6th gen accord i believe
Old Mar 31, 2007 | 11:36 AM
mclarenf3387's Avatar
You don't need to disconnect your battery, the fan can't turn on unless the car is on.
Old Mar 31, 2007 | 01:22 PM
B A N N E D
AHHHHHHHHHHHH im having some SERIOUS EMOTIONAL PROBLEMS!
haha... im getting so pissed right now..... the frekaing bolts conntecting it to the CAT are sooo rusted... wow.... im very agravated......... any suggestions? or just strait up work at it with some WD40 and elbow grease..
Old Mar 31, 2007 | 01:42 PM
WD-40 won't do crap. You need heat.
Go get a bottle of MAPP gas from Home Depot/Lowes wherever. You'll probably see it in a yellow bottle by benzomatic. It may come in a package with a push button igniter as well. Use that to heat the nuts then you will be able to break them loose with a breaker bar.
Old Mar 31, 2007 | 08:23 PM
MinTS's Avatar
Uhhhh i don't know about that other stuff Benzo....whatever, I say stick with WD40 if you already have a bottle and let the car run so that the bolts heat up. I agree about the heat. i just let the WD40 soak in for about 30 minutes and you should be ready to go.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
