Header Install prices in MI and billable hours
I have gone to 3 local shops to quote my header install.
One wants 3-4 hours labor at 95.00/hr
the second a flat rate of 225...says it will take all day
the third 3-4 hours at 80.00 / hr
These people are in Farmington hills, Livonia nd Novi
From HIGHER END SHOPS ONLY
What has been commonly paid and how many hours for a HIGHER END PROFESSIONAL to bill for
Not Asian
They say it will take 4 hours, but only really takes about 2. When I got mine installed, they said it would take all day. I ended up getting my car back around 2 in the afternoon and that was with a 30k mile service.
A CL-TYPE S 6 SPEED OWNER
better yet, do it yourself!! It not hard at all. Plus you will save yourself $225.00!! Plus, you can say i put them in myself! At least thats what i did!
Dragging knees in
I did it myself and I would be glad to give you a hand.
But as far as prices go, I would go with the 225 flat rate. If they run into a problem, it really could take all day and if you paid per hour, you would get raped.
By the way, what shops did you call? Have you called Godspeed in Novi? Mike is the mechanic there and he knows his shit and is really cool. I would highly recommend Godspeed. Good luck.
///M POWER
1 Post
i paid 160 for my install and they did it in 2 hours
i dont like going by an hourly rate cause what if an hour job take them 2.5 hrs cause they dont know what they are doing, you would end up paying for it
Hey,
can you tell me who did yours? I'm planning on gettin a header soon.
Do you live close to Livonia? I'm from Illinois. Was that price just for you or will they charge everyone $160?
Just repleaced a engine in a 02 TL-S and the owner brought in some Comptech headers, took me whoppn 30 min with air tools to put them on. I work at McGrath Acura
Dragging knees in
Amoo -- You sure you just want one header? That wouldn't do much for ya.
Just fucking with you. If you ever feel like driving up to Lansing, let me know. I would be glad to help you with the installation. I finished mine in a few hours; actually a total of 8 hours, but we were fucking around throwing the old exhaust manifolds at each other, eating pizza and having food fights in the midst of it. Actual labor time was like 3-4 hours without air tools. It was a pain, but I like working on cars.
Dragging knees in
I don't care that they mounted the engine tranversely. What pisses me off is the angle they put it in at. The rear one sits too low and deep and you have to do nearly everything by feel and touch.
I did the headers in the car, its fairly EZ to do with the strut tower brace out of the way. you only have 3 or 4 12mm screws that hold the exhaust manifold shields on, then remove the Ypipe off the cat, remove the 02 sensor with a 22mm open end wrench, remove the 3 14mm bolts from each exhaust manifold flange. Then remove the 2 12mm bolts that hold the Ypipe hanger to the frame of the car and just remove the Ypipe off. Now from the top of the car get the 12mm nuts off the exhaust manifold studs in the head- there should be 6 on each manifold if I remember correctly. With Air tools it takes 30 min to do in a car. I already had the stock manifolds on the engine after repleacing the heads and the block- 4 cracked pistons and 4 bent rods due to not chaning the oil. Installing the manifolds on a engine outside the car takes like 1 min to do with an air impact, then double checking the torque with a TQ wrench.
The anti-misshift
I got a quote from Suburban Acura is about $380 + tax
I am thinking to do it myself but I need to find a damn time to install it. Anyone in MI want to help
People keep calling them "headers" It's ONE header, not one headers. Comptech sell headers, which is plural.
http://www.comptechusa.com/instructions/ins038.pdf
Everyone, please stop calling it headers
Liquid Ice
Originally Posted by AmooManiaK
It is one header!
Check the TL/CL instructions ...
http://www.comptechusa.com/instructions/ins028.pdf
It even says, in step number 10, "Tighten headers: With the A-Pipe tightened to both headers..."
I'll do TL or CL headers for 175 bux for anyone in Chicagoland area. I guarantee my work, I won't guarantee the parts. PM me for a quote on other installs, I can do virtually anything on any car. I don't work on Cadillacs - got burned one time on a Northstar waterpump :P So lemme rephrase that, I do work on German, Korean, Japanesse and some domestic cars.
Dragging knees in
Originally Posted by LiQiCE
Actually, in 4 cylinder engines there's only 1 header. But on v6 engines there's usually 2 headers. If you look at the pictures of the Comptech headers for the CL/TL, there are two. 3 pipes for each header. So, in our case, we're buying Comptech Headers. 2 of them.
Just giving you a hard time, Liq.
Liquid Ice
There's "usually" 2 headers on V6 engines?
TLDude876
12-28-2016 03:18 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
