header bolt size
Old Aug 27, 2004 | 01:11 PM
rbf351's Avatar
Registered User
header bolt size
just got the headers from Nashua, what size are these bolts? i want to get them at the hardware store before i get home from work so i can install these
Old Aug 27, 2004 | 01:17 PM
rbf351's Avatar
Registered User
i hope the sizes are identical to comptech ones
just checked and they list the following sizes
6 - 10mm x 32 Bolts
6 - 10mm lock nuts
12 - 10mm washers
i'm getting crush washers to make installation easier for myself
Old Aug 27, 2004 | 01:59 PM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
good luck trying to find them at a hardware store, I went to several stores and couldn't find any thing similar in style. I did find some similar in size though. But the head was 17mm. Only I know that I can get OE bolts is to order them from from the dealer at +$6.00 each. However there is one place you might want to call. http://www.collegehillshonda.com/parts/
Try the accord parts.
BTW: if you do use bolts from the hardware store. The thread size is 1.25mm.
Old Aug 27, 2004 | 02:14 PM
rbf351's Avatar
Registered User
i only needed the 6 nuts/bolts that connect the headers to the a pipe, went to the store near my building and got me some
total was 5 bucks for
6 bolts
6 nuts
12 washers
also thanks for the site, but when i order parts it's easier to order them from http://partspeis.com
Old Aug 27, 2004 | 02:27 PM
JaDia4's Avatar
Censored User
6 bolts
6 nuts
12 washers
Good on ya! I'll have to try that web site, thanks.
Old Aug 27, 2004 | 02:51 PM
rbf351's Avatar
Registered User
not sure if i got the right washers
i got myself lock washer and someone once said crush washers, dude in the hardware store said they were the same but searching on google showed 2 different looking ones
i want the washer where when i make it hand tight i won't need 2 wrenches to tighten these down
Old Aug 27, 2004 | 04:49 PM
Pure Adrenaline's Avatar
Dragging knees in
Then you need lock washers. Crush washers do literally that -- they crush. They are made of malleable metal.
For your use, you want lock washers. You got the right ones. Do they have little ridges on the bottom side? If so, they are OK.
Old Aug 27, 2004 | 05:14 PM
JaDia4's Avatar
Censored User
BTW where did you pick up the nuts/bolts?
Old Aug 27, 2004 | 05:25 PM
rbf351's Avatar
Registered User
they look like this
rbf351's Avatar
Registered User
just a local hardware stock in manhattan, i used the specs from comptech's header instructions
Old Aug 28, 2004 | 01:47 AM
Allout's Avatar
Blown is Best
I just pulled off a set of Comptech Headers today. The bolt sizes above look correct.
The washers that come with the headers are just plain flat washers. Lock Nuts come with the kit and this is common for exhaust bolts. Lock washers sometimes do not hold up under the heat and will turn into flat washers. Once they lose their spring, they're worthless to keep the nuts from backing off.
If you get lock nuts, make sure they are all metal. Some lock nuts use a type of plastic like nylon to create the resistance.
tsx_boy
Dec 13, 2019 08:33 PM
neuronbob
23
Jul 16, 2019 10:48 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
Tribalheads
Sep 29, 2015 03:24 PM
dirleton
Sep 25, 2015 12:25 AM
