Have Tranny oil jet recall - how to refill with fresh fluid?
Old 11-03-2014, 11:00 AM
01RedCLS's Avatar
Question Have Tranny oil jet recall - how to refill with fresh fluid?
Dumb question, sorry: I have the 2nd gear oil jet recall oil line on my original CL-S transmission. I need to flush 3 quarts of the fluid and refill - watched a YouTube on how to drain the pain but I don't have the 17mm "ATF" bolt visible on the top of the tranny to refill with fresh fluid since I have the recall in place.
So how/where do I refill?
Old 11-04-2014, 09:06 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Remove the one small bolt that holds the oil jet in place and pull it straight up. Fill through the original hole. You wont break the oil jet, nor can you re-install it wrong.
Old 11-04-2014, 07:14 PM
2003 CL
hotclick56's Avatar
This photo should help.
Red arrow shows the bolt that needs to be removed in order to get to the fill hole (red circle).
Removing the battery will give you more room to work with.
TL-Rocket
04-29-2023 02:33 AM
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
ghuns
09-16-2015 04:26 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Have Tranny oil jet recall - how to refill with fresh fluid?
