has anybody retrofitted the stock cl road lamps?
Old Dec 24, 2013 | 07:20 AM
03-6/6's Avatar
M90booosted
Went to TRS the other day and saw they have these little matchbox projectors. 1.7" diameter. The only thing that makes me wonder is will the stock housing handle the heat? The backs look like plastic so it might work better. Just looking for insight here.
Old Dec 24, 2013 | 07:47 AM
yungone501's Avatar
J-series addict
I'd say if you're using a standard 35w hid bulb (which produces less heat than halogen) than yes. Just be sure and enclose the front half of the projector as it is not a sealed unit and will need protection from the elements. The factory fog light housing I know for a fact can take the heat of 55w halogens without getting damaged.
Gotta love them Matchbox's.
Old Dec 24, 2013 | 07:45 PM
OperationDarkie's Avatar
Ultra Negro
Im thinking of just saying screw it in putting in a light bar and sticking some led strips in my vent covers.
Old Dec 25, 2013 | 07:33 PM
03-6/6's Avatar
M90booosted
i tried that for a while. i found some small projectors out of a rx300 first gen and stuck them in the covers. it worked but didnt look that good.
Old Dec 26, 2013 | 02:15 AM
yungone501's Avatar
J-series addict
So what's the issue you're going through here? Sounds to me like you're more concerned about performance over looks. I'd recommend using some Hella XY (stands for extreme yellow) 3000k halogen bulbs. The yellow light really pierces the darkness and also looks great at night with the CL/TL's factory HID headlights (IMO). Other than that, you can shoot them babies (fog light housings) over to my shop (or any other installer on TRS's sight) and get a professional retrofit done and be done with it. Lol
Old Dec 27, 2013 | 08:19 PM
03-6/6's Avatar
M90booosted
i want both. lol. ive got a good friend that does reallllly good retro's on just about everything.
probably gonna go with the matchbox's w/ morimoto 5five kit.
ive been reading a lot on here about people using those hella bulbs and it melting the housings. i have some 18w nokya bulbs in mine now and i can see in 1 light where its starting to get melted.. :/
Old Dec 28, 2013 | 08:49 PM
yungone501's Avatar
J-series addict
I've seen lenses melt and housings melt before too. But it's usually with 55w variants over the 35w halogens. If its heat you're worried about then you may want to consider using HID's instead with a 35w oem ballast and bulb. Then use transparent yellow vinyl and to gain the yellow color. I did just this on my wife's MDX and my TL-S.
Old Dec 28, 2013 | 10:43 PM
03-6/6's Avatar
M90booosted
that does look good...
Old Dec 30, 2013 | 02:39 PM
fsttyms1's Avatar
Pick up a set of Fusion/Edge/Flex/etc.... Fog lights, (remove the foreground limiter if you want) and convert them to HID. They are sealed so all you would have to do is make a trim cover for the front oem driving..
Old Dec 30, 2013 | 06:19 PM
03-6/6's Avatar
M90booosted
I have one of those. I work at a ford dealer and I get them sometimes if we replace a broken one or something.
Old Dec 31, 2013 | 01:25 AM
aznboi2424's Avatar
Hmm I have 18 watt 921 bulbs in there and I don't have any melting.
Old Dec 31, 2013 | 08:17 AM
Rob7886's Avatar
I use led super bright and not the junk ones off of ebay
Good match for the HID lights
Old Dec 31, 2013 | 08:43 AM
fsttyms1's Avatar
Use them. Check out the link and all the output pics
http://www.hidplanet.com/forums/show...MKZ-Milan-etc-)
Unmodded 6k H11 bulb
Modded 3k H11
Old Dec 31, 2013 | 10:03 PM
yungone501's Avatar
J-series addict
Damn Kris, is there anything you DON'T have knowledge in?
Are you also a member of hidplanet.com?
Old Jan 2, 2014 | 04:03 PM
fsttyms1's Avatar
Not much, reading electrical schematics is probably my weakest point, but If i stare at something long enough i can usually figure it out. Yes i am, more of a lurker than anything but i am there.
Old Jan 2, 2014 | 06:34 PM
yungone501's Avatar
J-series addict
Diagrams/schematics are not something most people can understand very easily. Don't feel so bad.
Old Jan 6, 2014 | 11:59 AM
fsttyms1's Avatar
So when you going to build me a harness for my J32A2 (well J37a2 to work with a 07-08 TL-S ecu so i can run hondata
Old Jan 11, 2014 | 11:38 AM
yungone501's Avatar
J-series addict
Lmao, if it were that easy I'd be a rich fool. There's so much more to it than just wiring. I was thinking the other day about this and if we could mount the j35a8 crank sensor on the j32a2 oil pump, machine the j35a8 cam/crank trigger wheels down and fit the j35a8 cam sensor/cam sensor mounting plate, you my friend would have Hondata on your j32a2 (well, j37a2)....once the harness is wired up of course.
So when we doing this? I already have 70% of the requirements, I just need you to adapt the crank sensor.
Old Jan 21, 2014 | 02:05 PM
fsttyms1's Avatar
I dont think it would be that hard to adapt the crank sensor/gear. If i can get my hands on them ill do it
Yikes
May 3, 2021 04:29 PM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
Sep 15, 2015 06:44 PM
ellisd03tls
Sep 8, 2015 04:17 PM
