H&R Sport 50103 or H&R Sport 51858 for best looking drop on Cl-S
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Which one is it guys? Im looking for a nice even drop.
there is only 1 kind of h&r sport. are you sure the other part # isn't for a different car?
no there are two, I used the search feature of this site and they said that the 51858 were the original ones for 99-01 Tl and Accord, but then they made a 50103 for the Tl/Cl. Im trying to figure out which one gives a nicer looking drop on the Cl.
get the ones for the cl
This was a quote from hemants in a post:
A little known fact is that H&R sports (the accord ones) are better for the CLS whereas the 50103 are better for the TLS. The TLS has a heavier rear so I would go:
TLS : Comptech, 50103, H&R OE front only
CLS : H&R Sport, Eibach Prokit, Comptech, H&R OE
in that order
Does this make sense? Maybe the 51858 is the way to go for the cl? Its also cheaper to
in that order
i went back and forth between the 51858's and the 50103's also. i eventually went with the 51858...i had a hard time finding the 50103's (backordered everywhere). i'm glad i went with the 51858's because the lowering in the rear is just perfect. you are correct in that the 50103's dont lower as much in the rear...perfect for the heavier assed TL. Either drop will be fine...my opinion is that the 51858's are the way to go though.
the TL only weighs like 40lbs more.
again, i would get the cl-s springs.
Sold but not Forgotten...
Originally posted by Renegade
I think most members have 51858
here's a pic after the first couple of hours... the springs haven't settled yet...
hope this helps
TL rear is heavier than the Accord and CL.
There is no H&R sport designed for the CL.
51858 = designed for the accord, more suitable for the CL
50103 = designed for the TL
51858 tends to give a bit of a reverse rake on the TL
Dragging knees in
51858 uses dark blue Sport springs in all 4 corners.
50103 is a new kit based on 51858 to reduce the sag in the rear on TL's. It uses dark blue Sport springs in the front and grey OE Sport springs in the rear.
I have the 50103 with 2 12" in the trunk and it is sitting about 1/4 of an inch lower than the front. If I take my system out, the drop is dead even. Either way, I love it.
51858 seems to be less of a rake than Comptech which is probably a good thing for the CL.
Two thumbs up!
P.S. if you wanna see pics, right click, properties and then paste the *.jpg address in your browser.
Two thumbs up!
RSpyder
09-30-2015 12:46 AM
4drviper
09-23-2015 07:42 PM
