Ground Control Coilovers????
Old May 2, 2001 | 02:07 PM
FusionR TypeS's Avatar
i was just wondering if any of you guys have ground control coilovers on your CL-S. for those who have them, are they any good? does the coilover makes any noise and is the ride harsh or not? i had skunk2 coilovers and they really sucked. the ride was real shitty and made a lot of loud knocking noises. so if you have ground controls can u just post up how it is and if its worth getting.
Old May 2, 2001 | 07:36 PM
Dyno_CL-S's Avatar
dude... go with springs instead off coilovers. the coil's give more of a bouncie ride from what i've heard.
Current ride: 91 Dodge Colt.... no p/w, no p/l, no AC
Preiovus ride: 2001 CL-S, Black, dropped 2 inches, stock
Old May 2, 2001 | 11:21 PM
[VTEC]TL's Avatar
RWD convert
I have Ground Control coilovers on my TL. The back is adjusted al the way down and my car doesn't bounce at all albeit it's a bit stiff.
Y2K Satin Silver/Ebony 3.2TL
AEM ShortRam intake | Magnaflow quad exhaust | Ground Control coilovers | BOSCH platinum+4 plugs | Blitz coolant pressure riser | Factory Wing | Mesh grill | Body color door handles | Lighting:Polarg M12 sidemarkers/Opti-Blue Xenon HighBeams/Eurolite 168 Xenonbulbs/Hiper Strobes/Varad hyperblue LED scanner | 20%/35% Llumar Platinum tint | Räzo Shifter and Alloy pedals | 2 Rockford 10" XLC subs pushed by Boss Audio CLR60 amp | Escort Passport 7500
Factory underbody kit and wheel locks on 4/30.
Old May 2, 2001 | 11:28 PM
CLpower's Avatar
teh Senior Instigator
do not use those sleeve coilovers, they are horrible. My shop used to sell them to every civic and teg and they would all come in w/ problems. Broken sleeves, the coils would crack. GC is the better of the sleeve coilovers though. But i rode on them for awhile and was not impressed at all. The car still hasn't ridden the same, those things fuck w/ your suspension and should be left for cheaper cars.
Old May 3, 2001 | 02:03 PM
thanks man, im still deciding tho. i want springs because i know the ride will be good but i want coilovers because they are adjustable and i want my car low.
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
