Ground Control Coilover Installation...Please Help!
Old Aug 25, 2001 | 12:43 AM
SinnedTL's Avatar
Ain't No Other...
Im about to install my GC coilovers sooooon, and I need to know one thing...If I am not going to SLAM my car with these, do I have to trim the bumpstops, like it says in the directions??? If I just plan to have the car low as a prokit about 2 inches in front and back, do I still have to trim it??? Because I heard once you trim bumpstops and put stock springs back in, the shocks will make squeeking noises...is this true??? please give me some info. thanks!!!
Old Aug 25, 2001 | 12:58 AM
Jens H.'s Avatar
retired
you have mail
Old Aug 25, 2001 | 12:59 AM
RedLineTypeS
Guest
Posts: n/a
Originally posted by SinnedTL:
<STRONG>Im about to install my GC coilovers sooooon, and I need to know one thing...If I am not going to SLAM my car with these, do I have to trim the bumpstops, like it says in the directions??? If I just plan to have the car low as a prokit about 2 inches in front and back, do I still have to trim it??? Because I heard once you trim bumpstops and put stock springs back in, the shocks will make squeeking noises...is this true??? please give me some info. thanks!!!</STRONG>
Cutting the bumpstops wont make it lower it will however keep you from bottoming out prematurely if you hit a big focking bump or pothole. The squeek is not something i hear too much bout w/GC kit though.. its your actual shocks squeekin has nuffing do to with the bumpstops
[ 08-24-2001: Message edited by: RedLineTypeS ]
Old Aug 25, 2001 | 03:24 AM
Dynamic Type S's Avatar
9th Gear
I wanted to get Ground COntrols too, and am still planning to. However, my car is a lease, so if i have to cut the bumpstops, will it present a problem when i put the stock springs back in?
Old Aug 25, 2001 | 04:10 AM
RidinLow's Avatar
Scooby Guru
No, just keep the part you cut off & put it back in with its other half when you reinstall everything.
Old Aug 25, 2001 | 06:36 AM
9th Gear
Is there anyway to detect that the suspension was tampered with once i put the stock back?
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
