Got my 01 CL S yesterday
Old 03-10-2012, 09:43 PM
  #921
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,260 Likes on 4,875 Posts
You now have modern conveniences*!!
*for 1992
Old 03-10-2012, 09:56 PM
  #922
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,895 Likes on 1,307 Posts
*for 1992
It has had cruise for a while. The light is new.
Does your car have cruise?
civicdrivr (03-10-2012)
Old 03-10-2012, 10:18 PM
  #923
civicdrivr's Avatar
Yep.
On a serious note, why didnt you just pull out the bulbs for the TCS/Slip lights?
Old 03-10-2012, 10:19 PM
  #924
e30cabrio's Avatar
Soldered in leds.
204 & 229 are the cruise leds, I tried having them installed in my cluster, no go.
The only replaceable are directional & high beam. They were bulbs I got leds for them
Old 03-10-2012, 10:28 PM
  #925
civicdrivr's Avatar
Nissan, Y u no make bulb swap easy??
Old 03-16-2012, 09:52 PM
  #926
e30cabrio's Avatar
Installed the AFR and 80% of the oil temp & pressure gauges. They came with the wrong harnesses .
Old 03-17-2012, 02:06 PM
  #927
e30cabrio's Avatar
Ok ladies, here is a video. It was taken to send to my tuner so he can look at the AFRs, you can hear the exhaust for the first 10 seconds or so.
I don't want to hear about the bad quality, bad music, bad whatever.
Old 03-17-2012, 02:22 PM
  #928
civicdrivr's Avatar
That quality sucks!! It looks photoshopped!!
The second time you got on it it went a rich, but I wish I was at 12.4:1 at WOT
Old 03-22-2012, 06:13 PM
  #929
e30cabrio's Avatar
Oil pressure and temp gauges are wired. Sensors were supposed to go in but mechanic had an emergency so they will Monday.
TCS OFF switch lights up. I will be using the switch for my Forged fans to manually turn them on when I want to.
civicdrivr (03-22-2012)
Old 03-26-2012, 04:42 PM
  #930
e30cabrio's Avatar
Oil temp & pressure are in. Temp did not get above 140. Damn pressure gauge stays pinned at 100. Ordered a 140 psi gauge.
Old 04-06-2012, 09:52 AM
  #931
e30cabrio's Avatar
Picked up the COZ Akebono brackets yesterday. I have eBay brackets but am replacing the rotors and figured it couldn't hurt to get quality brackets. (not that I had any issues with the eBay ones)
Also got the oil pressure gauge finished.
Oil temp sensor:
Pressure sensor:
The stock gauge is 10lbs high at idle and up to 30 at high revs. I am not running over 120lbs, at wot it is near 100.
Old 04-06-2012, 04:14 PM
  #932
e30cabrio's Avatar
Rotors are here, they are mostly the right ones, I did not want drilled but I am teh happiez!
Old 04-06-2012, 04:49 PM
  #933
3.7L Nitrous Breathing CL
richardparker's Avatar
Did those come with their own special tool for removing the rotors from the hubs ?
Those are some weird looking screws.
Sweet rotors.
Old 04-06-2012, 05:02 PM
  #934
e30cabrio's Avatar
They need the hats to attach to the car. When I need to replace the disks I'll get the tool.
Old 04-06-2012, 05:03 PM
  #935
civicdrivr's Avatar
Id send them back for non-drilled rotors. Drilled = bad.
Old 04-06-2012, 05:08 PM
  #936
e30cabrio's Avatar
I got them for 523 shipped which you'd know if you checked your freaking email.
If I have a problem I can get new disks for 125 each shipped.
Old 04-06-2012, 05:12 PM
  #937
civicdrivr's Avatar
I check, but dont always have time to respond.
Drilled rotors like to play connect the dots. Why drop $250 extra when that happens when its not the part you ordered?
Old 04-06-2012, 06:21 PM
  #938
e30cabrio's Avatar
I agree drilled is not my preference. The fact is the description said drilled. I hoped it was not drilled which was what the part number referred to.
If I get 5k+ out of them I'll be happy.
They look cool! :P
Old 04-06-2012, 08:50 PM
  #939
e30cabrio's Avatar
This is at cold start up this morning.
The stock gauge is very high.
Old 04-07-2012, 09:13 AM
  #940
civicdrivr's Avatar
Ah, I got it now. I thought you ordered the non-drilled rotors. Makes sense now.
Old 04-07-2012, 09:18 AM
  #941
e30cabrio's Avatar
Disks came down to 122.
Amazon Amazon
Think I'll order them.
And a couple more rotor shots.
Old 04-07-2012, 09:28 AM
  #942
civicdrivr's Avatar
Im not impressed until I see a weight comparison.
Old 04-07-2012, 09:42 AM
  #943
e30cabrio's Avatar
23 vs 30 lbs.
Old 04-07-2012, 12:18 PM
  #944
civicdrivr's Avatar
Not bad. I didnt know the stock rotors were 30lbs
Is that each or for the pair?
Old 04-07-2012, 12:20 PM
  #945
e30cabrio's Avatar
Stock Z rotors are 13" and are not 30 lbs. Stock G37S 14"s are 30 each.
These are 23 each.
GTALK??????????????????????
Old 04-07-2012, 12:28 PM
  #946
civicdrivr's Avatar
Forgot that you have the 14 inchers.
GTALK!!!!!!!!!!!!!!!!
Old 04-07-2012, 01:20 PM
  #947
e30cabrio's Avatar
Yup.
GTALK!!!!!!!!!!!!!!!!!!!!!!
Old 04-08-2012, 09:41 AM
  #948
e30cabrio's Avatar
Got out to the garage at 6am and did the driver side, got lazy. Maybe do passenger later?
Replaced eBay bracket with COZ. Nothing wrong with the old one.
COZ next to eBay. These are opposite since I took off the driver side and installed it. I'll try to remember to get a picture of the passenger side.
Old 04-08-2012, 11:25 AM
  #949
e30cabrio's Avatar
Passenger side.
Old vs new 14" rotors.
eBay vs COZ brackets. I think I did not need to replace them.
Old 04-08-2012, 12:57 PM
  #950
civicdrivr's Avatar
They look nearly identical to me
Old 04-08-2012, 01:01 PM
  #951
e30cabrio's Avatar
Really? How's it feel to sound like my Wife?
civicdrivr (04-08-2012)
Old 04-08-2012, 01:05 PM
  #952
civicdrivr's Avatar
Smug
e30cabrio (04-08-2012)
Old 04-09-2012, 10:12 PM
  #953
Regional Coordinator (Texas)
nspec_ya4's Avatar
lol. those rotors look bad ass. and why did you switch out to infiniti brakes? if you mentioned it earlier, i must not have read it.
Old 04-09-2012, 10:32 PM
  #954
e30cabrio's Avatar
They are 4/2 pot calipers and 14" front/13 rear rotor OEM parts used in 09+ Zs and G37S.
I got the Infiniti calipers cheap on eBay.
Old 04-17-2012, 10:13 PM
  #955
e30cabrio's Avatar
Took the car to a differential specialist. He thinks the pinion retention nut is loose. Yet another mess up by my mechanic from heck.
6-900.00 to do and 2 days after all the parts get here possibly a week from Thursday.
He strongly suggested I not drive the car so I'll get to see what an open 3.5 feels like tomorrow when it goes in.
This is my fault because I thought whew, the car is done and all is well THE NIGHT BEFORE THIS STARTED
GAAAAAAAAAAAAAAA
Old 04-17-2012, 10:17 PM
  #956
StreetKA's Avatar
thats sucks :/
Old 04-18-2012, 05:51 PM
  #957
e30cabrio's Avatar
It does.
Diff swapped out. It's weird how different the car feels Having only the rear solid bearing reduces vibration, torque feels down, obviously being pushed by only one wheel feels totally different. The whine is gone.
Ring and pinion look ok, hope they are.
Old 04-18-2012, 11:08 PM
  #958
civicdrivr's Avatar
Hope it goes back together smoothly
Old 04-19-2012, 07:14 AM
  #959
e30cabrio's Avatar
Me too.
My main concern was the ring and pinion. They look ok to my untrained eye and my mechanic said no chunks/looking like there is minimal wear is good but he is not expert in differentials.
I have to wait for the parts to come in tomorrow. Damn pinion bearings/sleeve/nut were in Tennessee.
Old 04-20-2012, 05:44 PM
  #960
e30cabrio's Avatar
282.02 (with a discount) in differential rebuild parts.
Quick Reply: Got my 01 CL S yesterday
