good place to go to diagnose stuck brake problem in SoCal?
My brother recently got into an accident, it's his cl-s I'm posting about...
We replaced the pads/rotors less than a year ago with some quality stuff, racingbrake rotors, hawk hps pads.
apparently the front pistons are applying pressure at all times, causing the rotors to heat up/warp/crack. inner pads are worn out completely on the fronts, metal on metal. im thinking it might be the master cylinder??
the rear rotors seem fine, i haven't had the time to remove the wheel and take a look at the pad wear there.
i definitely need to have it looked at by a professional... where do you recommend i go? i live in irvine...
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
