good idea to put on performance 225/50R17?
Being I cannot afford to buy new wheels and tires. Would it make sense to buy some performance 17's with a 225 aspect ratio? Will I get better handling performance with more and better rubber? Thanks
go with 235/45/17 on the stock rims, that will give you better traction!! the 225/50/17 are ok from what most members say, but if 235's fit, why not go that route??
Re: good idea to put on performance 225/50R17?
The Screeching Toyo's
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
That is the set up I have, its almost exactly the same diameter as stock, so the speedo is still right on the money. The tires stick like GLUE!!!!!
Check my sig for more!!!
Do it! U Only Live Once!
Ask the tire dealer how much wear you should expect from perfomance tires compared to the standard. I heard somewhere that performance tires don't wear well, even if rotated. Check it out.
