The good and the bad of having a kit...
Old Jul 23, 2003 | 03:15 PM
Yumcha's Avatar
Good: Makes the CL-S stand out. Definitely gets more attention...and I think it really looks good...
And now for the bad:
Scraping pavement...I HATE THIS.
The "chin" has issues going down declines and now I have some nice gouges in my kit and my car isn't even lowered! So, my question is for those with the Versus kit or anyone else who used to own a lowered car with a bodykit, what do you do (or would do) to protect the bottom of the front lip??? Thanks!
Old Jul 23, 2003 | 03:21 PM
mc222's Avatar
I hate the Mets
How do you think the kit would look if you took off the front "chin"...
Old Jul 23, 2003 | 03:22 PM
rondog's Avatar
Former Sponsor
first off you post some pics, then you can start taking care if the kit. I am not getting the front lip from versus cuz I have a comptech drop and occasionally scrape. You should consider a custum front lip or alter the existing versus one. imagine having a vette and how much they must scrape stock?
Old Jul 23, 2003 | 03:30 PM
Yumcha's Avatar
Do a search, mc222...I think Ahmad310 posted some pics of his ride without the front spoiler...
Old Jul 23, 2003 | 04:01 PM
Yumcha's Avatar
Here it is! http://www.acura-cl.com/forums/showt...5&pagenumber=2
Old Jul 23, 2003 | 04:09 PM
mattg's Avatar
i would modify it and make it shorter. shouldn't be too hard imo.
Old Jul 23, 2003 | 04:13 PM
CLpower's Avatar
teh Senior Instigator
or, learn how to drive a lowered car. It doesn't appear you have springs so you should have NO problem driving it. Even if it was lowered you should still not rub if you know how to manuevar a very low car.
Old Jul 23, 2003 | 04:56 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
learning how to drive a lowered car includes the following
1)going slowly over bumps
2)coming at an angle to clear a bump one at a time
3)if you think you can go over it straight on, DON'T! better safe than sorry. Go around it or go at an angle.
4)get bags and raise that shit when you're "off roading" at the local grocery store speedbump.
otherwise you might try to spray the bottom with a truck's trunk spray. That will prevent the scraping from damaging the paint and cracking it all the way up. It's been done before. Ask your local truck spray place to do it. I don't know exactly what its called but it's the rough kinda black stuff that goes into the back of a truck.
Old Jul 23, 2003 | 05:46 PM
Yumcha's Avatar
Thanks for the advice! Well, maybe I suck at it but I do take declines/inclines at an angle...but, I guess it's not enough? I have scratched the center of the kit, left, and right...VERY annoyed...fortunately, you can't see the damage unless you look underneath the kit...but, still...
Old Jul 23, 2003 | 06:08 PM
civic4982's Avatar
you want to go over any bumps one wheel at a time. as in almost a 55 degree angle away from the normal direction. That'll reduce any damage at the center. oh yeah and if you have a polyurethane kit (I think the versus is) then you shoudln't worry too much about cracking or anything. however depending on the body shop that did your kit you may want to get that truck lining and protect the paint from all start to weather off and chip like crazy. body kits generally only look good for a year if you drive a lot and the body shop didn't do a good job of painting. I've seen it on a lot of friends rides who thought they'd save themselves some money.
do it right the first time.
Old Jul 23, 2003 | 08:55 PM
chef chris's Avatar
Homeless
Rhino liner...
Or, buy something similar at Pepboys...just paint the very bottom portion, like 1/2 inch up, that's it.
Old Jul 24, 2003 | 07:20 AM
fuzzy02CLS's Avatar
Most stock cars with low front ends(Corvette) have a black plastic lip under the front that takes the scraps instead of the front end. Maybe add something like that.
Old Jul 24, 2003 | 09:30 AM
Yumcha's Avatar
Rhino/box-liner...! I called some bodyshops and they said it just may hold against pavement and protect my finish...I think you guys have found the solution to my problem!
sockr1
Oct 1, 2015 01:31 AM
carz0159
Sep 20, 2015 06:11 PM
PortlandRL
Sep 14, 2015 12:01 PM
NSolace
Sep 3, 2015 08:02 PM
