Gauges for the S/C???
aka gimmesomesugar
OK, I've ordered the following gauges for the s/c(the s/c will be here in a week or two)...
-boost
-fuel pressure
-a/f ratio
-tranny temp
All gauges are full-sweep electrical ones from Autometer.
I've been reading up on the internet about Autometer and a lot of people are saying that they are very inaccurate and not worth the money...even though they are fairly inexpensive compared to other brands(ie. Defi).
So, should I stick with Autometer...even after reading all these negative reviews/feedback?
Or, should I consider other brands? With this being the case, what other brands are good?
-boost
-fuel pressure
-a/f ratio
-tranny temp
aka gimmesomesugar
I really like the Defi-Link Meter BF gauges
They're completely blacked out when the ignition is off and light up when the car is started.
Unfortunately, they only come in:
Turbo kPa(I guess this gauge cannot be used in conjunction with a s/c)
Oil Press. kPa
Fuel Press. kPa
Oil Temp. oC
Water Temp. oC
Exhaust Temp
Oil Press. kPa
Fuel Press. kPa
Oil Temp. oC
Water Temp. oC
Exhaust Temp
Re: Gauges for the S/C???
-boost
-fuel pressure
-a/f ratio
-tranny temp
-boost
-fuel pressure
-a/f ratio
-tranny temp
But I would forget about the A/F gauge unless you just want a flashing bar graph.
As for Autometer, I have been using them for years without complaint and are more than accurate enough for their intended use.
aka gimmesomesugar
Re: Re: Gauges for the S/C???
Originally posted by scalbert
I would go with a mechanical boost gauge as it is significantly less expensive and just as good. The fuel pressure is fine as well as the transaxle temperature.
Yeah, I'd like to go with 4 gauges. The reason being is that I'm going to do a custom fibreglass dash kit with the a/f gauge, f/p, and transmission temp just above the stereo. Of course the note pad tray will be removed to facilitate fitting the gauges in. Three gauges there will look a whole lot better than just two. My installer recommended that the boost gauge be placed closer near the stock gauge cluster or steering col...better line of sight so I can keep an eye on it while driving.
Which line of gauges from Autometer is the most accurate?
Re: Re: Re: Gauges for the S/C???
All off their gauges are generally the same accuracy. They are analog needle gauges regardless of the measurement technology. Meaning that you can't really read them to the accuracy of which they are measuring. It is meant to give you an idea of the measured value at a glance.
aka gimmesomesugar
Re: Re: Re: Re: Gauges for the S/C???
If four gauges are to be used I would suggest dropping the A/F gauge and replacing it with an oil pressure gauge. That is much more useful.
So, I'll have the fuel pressure and oil pressure gauges.
Since there isn't a tranny temp gauge in this line, would it be a good idea to use the oil or water temp gauge for it? My installer said it would be possible to hook up one of these gauges to measure the tranny temp since they are just temp gauges.
I did a search to find the operating range of the tranny temp...160 being the minimum operating temp and 240 being the maximum with anything above that resulting in tranny failure. Since fahrenheit or celcius was not posted, I assume it's in fahrenheit, correct? Since these gauges are in celcius, which one should I use? 160F = 70C and 240F = 116C. Logically, I should use the oil temp gauge since it gives me a higher range(50-150 as opposed to 20-120), correct?
aka gimmesomesugar
Is it possible to use this in conjunction with the s/c or should I use one that is in PSI units?
or
Actually, I think all these boost gauges are for turbo applications...I'm confused now...need help to clear this up
aka gimmesomesugar
Originally posted by GOT PSI?
IMO, I would stick with a non-KPA unit unless you are use to converting BAR into psi's. I've used a 30psi boost gauge on my s/c 5.0 with no issues.
Re: Re: Re: Re: Re: Gauges for the S/C???
Yes, it is in Fahrenheit.
The boost gauge that I have in mind has "turbo" on it and is in kPa units.
I know how expensive the electronic gauges are, and for a few extra $$$ you can get a wideband o2 meter that will give you acurate A/F numbers. The display is not round, and will not match your other gauges, so looks are not part of the deal,... however IMO acurate A/F ratio is very important with a FI set-up.
http://techedge.com.au/
Question? I'm assuming an VAFC would not give you all of the readings without having to have the gauges displayed? Is this correct? I too am getting my SC installed in a few weeks but would rather not go with a bunch of gauges, mainly because I don't want them to be seen. But wouldn't an VAFC show me the same readings? HELP!
aka gimmesomesugar
Looks like I may not be getting the gauges after all.
I'm looking into the HKS Camp now.
http://www.hksusa.com/categories/?id=1082
Instead of putting a whole bunch of gauges in the dash, I can have the gauge meters pop up on my Pioneer LCD...I might as well put the AVH-P7500DVD to use while I'm driving.
But, I'll only get it if it can measure fuel pressure, tranny temp, and oil pressure. Otherwise, I'll stick with the autometers.
Analog Display – The analog display can indicate speed, RPM, gas mileage, fuel consumption and injector opening percentage. The CAMP includes peak data memorization and allows the scale to adjust according to current driving conditions.
No, the VAFC would not display the needed parameters.
Just FYI, don't bother with the VAFC as it is worthless on a blown vehicle.
Originally posted by Type S Lady
Do I need any gauges or are the people with SC's getting them for looks? I only want to get what is absolutely necessary.
-boost
-fuel pressure
-a/f ratio
-tranny temp
-boost
-fuel pressure
-a/f ratio
-tranny temp
aka gimmesomesugar
Originally posted by 97-3-pt-OH-C-el
were you in 6th gear? that Vancouver night scene video?
You know...that place where you usually don't get any respect.
In this forum, you got to contribute. Since you don't go back to off-topic.
aka gimmesomesugar
message boards arent where i look for the most respect you tool
Well, where do you get it? Obviously you don't get much of it in your real life.
man, i wish i got respect
It's Go-Time.
Re: Re: Re: Re: Re: Re: Gauges for the S/C???
i go to school and people call me a "n00bie".. much like here.
Re: Re: Re: Re: Re: Re: Re: Gauges for the S/C???
What grade are you in where you're still called a noob?
mrkingstonvi
02-22-2016 01:53 PM
