Which gauges to buy with the S/C
Is the only option (from Auto Meter) the Phantom series gauges? What color do they light up at night?
I need a 0-100psi fuel pressure and a boost gauge that tops out at 20psi MAX. Hopefully more like 15psi.
I want white faced to match the stock dash.
I guess I go with these correct?
Blown LS6!!
Those would look good. I have the carbor fiber boost gauge and I think it looks pretty good. I haven't bought a fuel pressure gauge yet. They're a bit pricey and I'm not sure I really want to up the boost more anyway. After unplugging the IMRC I haven't had any issues w/ pinging.
Bleed Honda Blue
My Autometer electric fuel guage is still sitting in the box. Don't know how to installed it, Scalbert have some plumbing on his. I just didn't feel save to do what he did.
Originally Posted by BlueCLS6
I think the Ultra-Lights match pretty well. I have the 0-100psi fuel and 15psi boost/vac. Check out my Avatar.
So they will light up at night, etc.
Mechanical or Electrical?
I know I need electrical for the fuel pressure.
I was thinking about doing up a braided system using all -AN fittings, want one.
You already know my suggestion, but i think the Ultra-Lights would indeed match up pretty well.
Almost all the gauges are back lit by a bulb which can be made red/green etc. by putting a supplied bulb "condom" over them.
Swim Bike Run...
Just a recommendation - don't run fuel into the cabin!!
Autometer Ultra-Lite #4376 for boost and Autometer Ultra-Lite #4363 for fuel pressure - they should be under $350 for both. These are the guages Blue and I use.
Buy them on-line... probably the best price - try Limit Engineering and ask for John.
ex 6 Speed owner :(
Originally Posted by allmotor_2000
I second Blue - the silver edges add to the effect and the guage cluster is silver, not white! I just put the red cover on the bulbs and it looks mean!!
Duh... mine are all bright white right now. I am going to go put the blue one on there!
Revving at 9K...
Have you checked out Defi Guages? I have 2 of them. Boost and EGT, both are 60mm.
The kit comes with the controller until that allow more guages to be plug in in the future if you so choose. I bought them for my S2K, but then changed my mind on installing them.
If you are interested, let me know.
http://www.defi-shop.com/product/meter/meter_top.html
Defi > Autometer
Defi > Autometer
OHHH THAT's what those red and blue thingys were for!?
Primary colors....
I favor the Lunar Series from Autometer. the Phantom series is also very nice. they are indiglow green.
http://hp.autometer.com/buyers_guide...uct_lines.html
Originally Posted by darrinb
u buying the s/c brand new steve??
Bleed Honda Blue
13.68 @ 102.56
Originally Posted by flint
you have a pic of them mounted?
I tried them and this is the reponse I got:
Steve,
Sorry, I can't help you. We only sell turbochargers.
Sorry for the delay. I have been at Bonneville.
Regards,
John
Regards,
John
You can get the gauges in question at Summit Racing or Jegs:
http://www.summitracing.com
http://www.jegs.com
http://www.jegs.com
Damn you have one too!!! I just when to my local machine shop to get a custom T-fitting fabricated. It will cost me $75 to make one. I haven't got it back but if it doesn't work, Yes I want that too. Will let you know soon. Thanks
Here is all you need to make the change:
http://store.summitracing.com/defaul...AR%2D100192ERL
http://store.summitracing.com/defaul...AR%2D935106ERL
With those two parts you can use the hose provided by Comptech and have the 1/8 FNPT port for the sensor.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
