Gauge install
Old Feb 24, 2005 | 07:28 PM
2slow4u's Avatar
Gauge install
Iam putting in some gauges and was wondering what wire do I tap onto for the lights to work with my car lights. I also need to get to the ecu behind the radio and was curious what was the best way. Thanks.
Old Feb 24, 2005 | 07:34 PM
NiteQwill's Avatar
Adventurist.
You can tap the wire the come from the interior cabin dimming switch I believe. The ECU can be access from the passenger side footwell. Just look up when you get your head down there.
Old Feb 24, 2005 | 07:42 PM
2slow4u's Avatar
Ok i was wondering about that dimming switch because its perfect place to tap, will i be able to tap onto a wire on the ecu for air fuel gauge.I know its the white wire just curious about space?
Old Feb 24, 2005 | 08:05 PM
NiteQwill's Avatar
Adventurist.
You have plenty of space down there. Just use a micro-tap, not the industrial sized (think: 12 GA) wire taps.
Old Feb 24, 2005 | 09:12 PM
2slow4u's Avatar
Thanks alot !
Old Feb 25, 2005 | 09:11 PM
2slow4u's Avatar
Iam installing my gauge right now and there are several white wires. There is one solid white wire in each different plug in connector. So which plug in conector do i get it off of ?
Old Feb 26, 2005 | 11:13 AM
2slow4u's Avatar
Thanks for the help.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
BoricuaTL
Apr 8, 2016 01:08 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Sep 21, 2015 08:44 AM
TxRzrBk
Sep 17, 2015 01:07 PM
