Gauge install
Gauge install
Iam putting in some gauges and was wondering what wire do I tap onto for the lights to work with my car lights. I also need to get to the ecu behind the radio and was curious what was the best way. Thanks.
Adventurist.
You can tap the wire the come from the interior cabin dimming switch I believe. The ECU can be access from the passenger side footwell. Just look up when you get your head down there.
Ok i was wondering about that dimming switch because its perfect place to tap, will i be able to tap onto a wire on the ecu for air fuel gauge.I know its the white wire just curious about space?
Iam installing my gauge right now and there are several white wires. There is one solid white wire in each different plug in connector. So which plug in conector do i get it off of ?
BoricuaTL
04-08-2016 01:08 PM
mrkingstonvi
02-22-2016 01:53 PM
