Fuel Modifications
Old Feb 11, 2002 | 02:06 PM
DG-T-S's Avatar
Fuel Modifications
I think we can all agree on the fact that our cls's can now breathe a whole lot better. for the most part, everyone on this forum has intake/ exhaust/ header upgrades. and sooner or later, everyone will have a res under their hood. all of these mods increase the flow of air through our cls's but how can we make sure that our mixture is correct?
Does anyone know the flow rate of our injectors?
maybe those of you who have tuned your v-afc's aren't getting the best results b/c your cars are not delivering enough fuel.
i've taken the first step towards improving my car's fuel efficiency by getting an ignition. the throttle response is much crisper and acceleration is definitely quicker.
what about injectors and a fuel pressure regulator?
i'd just like to know if these are necessary components for the way we've modded our cars.
These are just a couple of things i was thinking about at work today. hope to hear lots of responses
Old Feb 11, 2002 | 02:15 PM
JasonT's Avatar
FOR THE MOST PART, EVERYONE ON THIS FORUM HAS INTAKE/ EXHAUST/ HEADER UPGRADES
I don't.
Old Feb 11, 2002 | 03:24 PM
CO-CL-S's Avatar
I don't either, As to fuel, we have a computer that monitors the fuel (with the O2 sensor, other thingys?).
Old Feb 11, 2002 | 03:25 PM
DG-T-S's Avatar
anybody else have something "POSITIVE" to add?
Old Feb 11, 2002 | 03:37 PM
sidemarker's Avatar
DG-T-S
what kind of Hi-Flow Catalytic do you have? random tech?where did you get it from? Do you think it will fit with the stock piping? and i noticed you have upgraded your ignition system. do u think its worth it if your not running nos? and where did u get it from?
sidemarker
Old Feb 11, 2002 | 03:42 PM
johntypes's Avatar
Did you add a inline fuel pump?
did you dyno your car running nos?
I F SO DID YOU HAVE A FUEL AIR RATIO METER HOOKED UP?
Old Feb 11, 2002 | 03:51 PM
DG-T-S's Avatar
sidemarker-
the hi-flow cat can be welded between the factory piping & comptech headers. the ignition system is worth it b/c there are definitely gains w/out spraying. it's made by HKS.
Johntypes-
what purpose do your fuel pump & regulator serve you?
i'd figure you're the man i need to talk to b/c you're the only person who seems to acknowledge a car's fuel needs. any advantages?
Old Feb 11, 2002 | 04:03 PM
TheModMole's Avatar
13 Second CLS Defender :)
Will help a bunch.. I think Scalbert just mentioned we flow 31/32 lbs..... an adjustable fpr and larger injector will help.. but really after you do some internal mods (SC/TT/3.5/N20) Search for scalbert or EricL? posting one of them went through our injector DC's and optimal rates...
Old Feb 11, 2002 | 04:04 PM
sidemarker's Avatar
DG-T-S
where did you get the hi flow cat and ignition system? what are the part numbers and how much were they?
sidemarker
Old Feb 11, 2002 | 06:12 PM
Ultimac's Avatar
Did you change your injectors? Let me know when you get your car hooked up I'm interested too. PS. Don't leave your bottle warmer on, you heard about the guy that blew his garage off didn't you.
Old Feb 11, 2002 | 06:17 PM
Ultimac's Avatar
I've got the comptech fuel press reg, and fuel pump, but i've been waiting to put it on ...
Old Feb 11, 2002 | 06:46 PM
Rescuer's Avatar
Evil Bob Knieval
Old Feb 11, 2002 | 07:09 PM
scalbert's Avatar
The injectors can flow more than enough for the current mods. I guess the real question is if we need additional fuel, we may be too right to begin with?? I'm not saying that is the case but it seems to be an unknown. Without properly testing, it is all a guess.
But IMO, the fuel system is more than enough to around 375 crank HP, maybe even more. My previous calculations were based on a blown engine, not NA. Nobody is near 300 WHP!!
But could a little more or less fuel be better, well just don't screw with the idle or cruise value or any tuning is wasted. Only tune for WOT. But again, IMO, fuel is the last area we should be looking at; the factory now does pretty well there. As Eric and I have quickly tossed around, there seems to be something in timing with these cars. But with timing comes the need for a little more fuel so that needs to be balanced, but one step at a time.
I'll just say that things will be tested soon with some (once again) cheap and dirty testing. But enough to give an idea of directions needed.
Old Feb 11, 2002 | 07:23 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
The more timing...the more fuel...the more bang you get...In the optimal mixture of course..
Old Feb 11, 2002 | 08:05 PM
johntypes's Avatar
to ulimac what kind of fuel pump did you get in line or in take?
To dg-ts bigger injectors only needed with turbo or supercharger
To side marker rand tech converter gave me more hp but less tq. car ran slower at track conv. used was for accord.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
joflewbyu2
Oct 8, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
