Fuel additives
Old Jun 14, 2009 | 07:01 PM
VIPCLS's Avatar
P.
Fuel additives
I have a 01 CLS and was wanderin what you guys think bout adding fuel injecter cleaner, octane booster, oil treatment ect. Do you need to do this to a acura engine??Bout to hit the 100k mile marker here soon, and was wanderin if that could be a nice treat for the engine. Also when do i need to change spark plugs. Any input appreciated.
Old Jun 14, 2009 | 07:33 PM
AnthraciteBeast's Avatar
As long as the car was well maintained, I don't see a need for any additives.
As for the plugs, 105K
Old Jun 14, 2009 | 07:46 PM
Rajca's Avatar
wham bam thank you ma'am
just do the seafoam treatment.
Old Jun 14, 2009 | 09:32 PM
CH46ESeaKnight's Avatar
Be careful with oil additives. A engine with 100K will likely have some scaring on the bearings. That scaring is likely filled in with thick film of dirty oil and junk. You don't want to clean it out. If it gets cleand out it can cause more problems. It can do the same thing for your engine seals, if it cleans them out it may cause a leak.
I try to use quality fuel like Cheveron w/ techron as often as possible. Since I moved I can not ge it anymore. So I use the Shell w/ nitrogen, which is controversal, and seems to be the best for this area. But I know it is better than that shit Citgo sells.
I did Sea Foam last year through a vacum line and it did make a diff in the way it ran, much smooter.
I never add anything to the oil.
Old Jun 14, 2009 | 09:45 PM
VIPCLS's Avatar
P.
Ight cool thats what i was thinkin from most all of the comments. I have a buddy that keeps tellin me to try i think amsol products, and i keep thinkin no. I ran a octane booster in one of my past vehicles and the engine ran like crap.
Old Jun 14, 2009 | 09:48 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
To fuel additives, I say, "nay".
To seafoam, I say, "yay" (if you change out your spark plugs afterwards).
Old Jun 14, 2009 | 09:59 PM
The only octane booster I found that make a noticable diff is the NOS race formula. It is the one in the black can/box. It did make the car run better. 99% of the time fuel at the pump does not hold its octane. If it says 93 oct then it will likely test out to 90 to 91. I only do it every once in a while. When I feal like driving hard.
The CLS needs super unleaded fuel due to 10.5 to 1 comp. Running a little higher octane will just healp it run better. Or to its full potential I should say. If you run less than the needed octane then yoour engine is pulling back on the timing, thus your loosing power.
Old Jun 14, 2009 | 10:23 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
seafoam for sure
Old Jun 14, 2009 | 11:10 PM
Dan's Avatar
Dan
Confused
Techron or Toyota EFI Cleaner for fuel additives. Toyota EFI Cleaner comes in a STEEL can, as the stuff will eat through plastic bottles.
Old Jun 15, 2009 | 06:26 AM
davepaul033's Avatar
I heard nos is a good additive
http://www.gixxer.com/forums/showthread.php?t=226570
Old Jun 15, 2009 | 08:52 AM
civicdrivr's Avatar
Originally Posted by davepaul033
I knew someone would post that.
Old Jun 15, 2009 | 10:22 AM
jaysizzlecity's Avatar
B A N N E D
93 octane should be just fine.......
Old Jun 15, 2009 | 02:07 PM
VIPCLS's Avatar
P.
Whats the link for the seafoam method? I want to check it out, i did a search an really couldnt get the results i was lookin for.
Old Jun 15, 2009 | 03:06 PM
Rajca's Avatar
Under 2nd gen tl, look for a "diy sticky" that will have the seafoam meathod and lot more
Old Jun 15, 2009 | 03:19 PM
TheWeez's Avatar
I Wanna Beer
Don't know about where you live but in Minnesota and other states in the midwest they require a government body to test stations pumps and gas quality every 6 months or less to verify that what they're selling as a gallon or as 93 octane is in fact correct. You buy 93 and you get 93.
Old Jun 15, 2009 | 03:29 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I use fuel additives evet 2-5 k miles..
I just bought some Redline SI-1 and used it last week.
I heard alot of good stuff about it but i havent really noticed a difference.
I heard its good to clean the fuel rails!
Old Jun 15, 2009 | 03:35 PM
EliteDemon's Avatar
The TARDIS is my
I don't really have time to read 125 pages but, did the guy say if he was serious about the NOS?
Old Jun 15, 2009 | 03:58 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
why have none of you mention Z-max... I have not touched fuel additives since my acquisition of the CL... but... it worked wonders on my Ford Probe and my brothers Prelude...
It's 3 part... one trans, one engine and one fuel...
Now the trans one actually makes the tranny SHIFT SMOOTH... I SHIT YOU NOT
the fuel one WHO KNOWS...
and the engine one basically makes everything inside there run as good as possible... It cut down my bro's oil burning FURRY by 50%..
So my question is... WHAT do you guys think about z max for our cls?
Old Jun 15, 2009 | 04:17 PM
EliteDemon's Avatar
The TARDIS is my
^there have been threads about it, most suggested bad things.
Old Jun 15, 2009 | 10:07 PM
Those little stickers on the fuel pumps are yearly not bi-yearly and they are for Weights and Messurments. So when you buy a gallon you get a gallon. Fuel looses it potency from sitting in a tank. Super unleaded is used far less than regular. Super will degrade over time as it sits longer. I PROMISE you if you went and bought a gallon of your favorite super unleaded and had it tested it WOULD NOT test out to 93 oct.
And if your buying fuel from a small locally owend store it is going to be even worse. I've seen it myself where the ass hole store owner was topping of his tanks with water. I only buy from the larger gas stations. Non of these BS corners stores.
Old Jun 15, 2009 | 11:27 PM
dave586270's Avatar
Chamorro
Yeah this DIY was really easy to follow. I did it and really noticed a difference. I mean its not gonna give you new engine or add horsepower, but the car runs smoother, idles nicer and just feels better. Really pay attention to your car while you warm up the engine (first part of DIY) and then pay attention after you run it through the vacuum line. Here is the write-up:
https://acurazine.com/forums/showpos...52#post2033721
Old Jun 16, 2009 | 12:24 AM
Im just saying. Will it be enough to notice a diff in power? Maybe not. But I do notice a diff when I use (Seldemly) the NOS race formula. So I know the car likes the higher octane.
Old Jun 16, 2009 | 12:31 AM
VIPCLS's Avatar
P.
Thanks for the link dave586270.
Old Jun 16, 2009 | 01:51 AM
dave586270's Avatar
Chamorro
No prob man. Took me a while to find it. The first time I just poured the whole thing in my gas tank like the bottle said. I was disappointed cause of how everyone talked about the difference. I didn't feel shit! But when i found that I was def happy. Good luck
baelim
May 10, 2018 09:53 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
jmaxima03
Sep 27, 2015 10:22 AM
