front wipers going off the windshield at high speeds
Old 10-27-2002 | 08:25 PM
chikai's Avatar
trying to get a lil V-I
I was driving on the highway the other day and it was raining pretty damn hard. I turned my front wipers from the normal speed to the highest speed.
I noticed that the wipers were making a knocking sound at the furthest point of the sweep. Then I turned it back to normal speed and the sound went away. The knocking turned out to be the wipers hitting the frame of the front windshield at the top left corner.
Does this happen to anyone else's ride? Should I take it in and get it checked?
Old 10-27-2002 | 08:31 PM
russianDude's Avatar
Re: front wipers going off the windshield at high speeds
I have the same thing... this could be normal
SinnedTL's Avatar
Ain't No Other...
just do it yourself, its easy, open the hood, un-bolt it at the base, then reposition to your liking, and then bolt it back on... 5 minutes
Old 10-28-2002 | 11:23 AM
dmcconnell's Avatar
I had the same problem. It's warranty work. The dealer rectified the problem by adjusting the position of the wiper arm.
Old 11-30-2012 | 07:09 PM
thewrangler99's Avatar
I noticed this same problem today! In my case after 3-4 sweeps driver side wiper start hitting the top left corner of the windshield! Can somebody provide the fix with the pictures!
Old 12-01-2012 | 12:58 AM
ML03CLS's Avatar
At this age you most likely you have bushing(s) worn in your wiper linkage. Easy and cheap enough to replace both linkage arms and not worry about it further; a relatively common problem. Here are the part numbers (for an 03, assuming its the same):
76540-S0K-A01 ROD UNIT A (LH)
76550-S0K-A01 ROD UNIT B (LH)
Old 02-03-2013 | 01:09 PM
gtpilot's Avatar
5th Gear
I had the same problem. I adjust the position of the wiper arm.
and still has a little hitting but them i sold the car was a 00 TL with 121Kmile and the transmission was good
Old 02-03-2013 | 11:05 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
happened to me it was the spring that was fucked in the arm... but honestly it's still not 100% on the highway.. but it is like 90% better i aint complaining
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
08 NBP TL
09-08-2015 08:49 PM
Sixers12
ILX
09-06-2015 07:54 PM
Quick Reply: front wipers going off the windshield at high speeds
