Front Signal Bulbs
one way to take out those bulbs, is to take off both headlights. but that would be too much work. you could jack up your car and take off both front wheels(for max working room). or you could twist the wheels to allow you to either completely take off or partially move the wheel well's lining to allow you to get your arm to reach the connections that power the lights. you would have to do a 1/4 turn to the left to loosen and pull the bulb out of the housing. then you could undo the electrical power cord/harness to let you pull off the bulb with it's socket to quickly replace the bulb. preferably without making skin contact with any of the bulbs. good luck.
sockr1
10-01-2015 02:31 AM
