folks w/ tein ss ---->
Old Feb 24, 2003 | 01:45 AM
mattg's Avatar
i heard a few people saying that there suspension bottomed out over big bumps. aka going too fast on crappy roads or big a$s speedbumps.
did you mean your car actually scraped the ground? because mine has a few times :o
the perches are at 3 turns from the bottom, must be at -3" or so. the other thing thats killing me is my snow tires are 215-45's.
so my cl is dropped like 3.5"
dampers set to - front 10, rear 8.
i'm gonna put on my rims and some 225/40-18 in a couple weeks
Old Feb 24, 2003 | 02:28 AM
nate'sCLS's Avatar
I didn't know you went with teins mattg, you were on h&r race before right?
Old Feb 24, 2003 | 02:34 AM
mattg's Avatar
yep, h&r race/koni
Old Feb 24, 2003 | 10:20 AM
peiqinglong's Avatar
You have to break the Teins in for like about 500 miles or so. No hard driving with them. The shocks did to "open" up so to speak. I suggest you re-raise your suspension to like only a 2inch drop and after 500 miles, relower it. I used to have some problems, but after I found out they had to be broken in, I did it and now they work great. If you insist on leaving it at that height, be very careful about bottoming out, you might blow the shocks.
Old Feb 24, 2003 | 10:54 AM
chikai's Avatar
trying to get a lil V-I
Gawd damn...I think you have the lowest setting out of any of the TEIN owners on this board. Hope you have some camber adjusters too or you'll be going through tires every 5000 miles.
The bottoming out ppl are referring to is the struts hitting the rubber bump stop. Like Pei said, be very careful you don't blow out your struts. I don't know how the roads are in Portland, but I know there is absolutely no way I can run 3 inch drop around here.
BTW: I didn't know there was a break in period either...what is the point of that?
Old Feb 24, 2003 | 01:21 PM
Tein recommends going easy on the shocks for awhile so that they're broken in...I believe it's mentioned somewhere in the little tiny booklet thing that comes with the Teins...found it...look under the topic "Before/After Installation"...under the 6 bullet...this is what it says "Upon installation, avoid rough handling and drive slowly."
Also another thing to note...on the 6th page...under caution "The dropping of the ride height correlates to the spring rate Depending on the spring rate, the ride height may not drop as easily." I'm getting the upgraded Tein springs soon...I'll tell you how that goes matt.
Old Feb 24, 2003 | 04:31 PM
mr. big's Avatar
hmmm, i dont think i followed that break-in period...but i know i tested the car out a few times right after i got em....do u guys think id be suffering the consequences now? I have never bottomed out once....
Old Feb 24, 2003 | 04:42 PM
probably nothing too much to worry about...I didn't know about the break in and bottomed like 2 or 3 times during break in...i'm find now.
Old Feb 24, 2003 | 04:50 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
I have a'pexis. I'm slammed.
Old Feb 24, 2003 | 05:18 PM
Rod's Avatar
Rod
Any problems or other negative comments about the N1 Sport Dampener? How's the ride quality?
Old Feb 24, 2003 | 11:35 PM
mattg's Avatar
where does everyone have there dampers set to?
i like how they are easily adjusted without the tool
Old Feb 25, 2003 | 12:45 AM
fronts: 8, rears: 8. Good balance.
Old Feb 25, 2003 | 12:59 AM
CL FWD SPEED's Avatar
What to do, what to think
yep me also....I just put them on today =)
Old Feb 25, 2003 | 03:01 AM
mattg's Avatar
notice how the beer bottle can't roll under my mudflap :o
Old Feb 25, 2003 | 08:35 AM
chikai's Avatar
see sig...
so how do you adjust the rear dampeners?
Old Feb 25, 2003 | 02:46 PM
mattg's Avatar
actually, i haven't put my seat back in
Old Feb 25, 2003 | 03:16 PM
dbox's Avatar
whoXwanXsum
ok mattg, u got the drop i want. teins it is. fuck this h&r race bumpy shit.
DigiBox's Avatar
Lots of JDM parts on my
Damn matt, your ride is low!! Looks sick man!
Old Feb 25, 2003 | 03:22 PM
Not N1...you can only get those if you have an Integ or civic or whatever else. I have the WS. The ride is good...probably not as good as the teins if its set correctly, but then there is no dampening control. I mean for the price tho, the teins offer a lot more.
Old Feb 25, 2003 | 04:04 PM
Rod's Avatar
Rod
Thanks, I figured the Teins probably give a better ride, but what I'm really asking I guess is have you bottomed out your suspension like people with the Teins have?
I wonder which would offer better ride quality the apexi or the Teins with the next higher spring rate option.
Old Feb 25, 2003 | 04:44 PM
If by ride quality you mean a nice soft luxury ride, then probably the Teins because u can set the dampers down to the softest. The springs that come on the Teins are rated for the Accord, so it's already soft since our cars weigh more.
Old Feb 25, 2003 | 06:30 PM
JRock's Avatar
Old timer
mattg - so you got Teins now?
I love your drop. Reminds me of how low my Nex SS drop was. That's got to be around 4" drop from stock.
Also, bottoming out, at least where I am, means your shocks/struts are fully compressing and hitting the bump stops. That is what I experience. My car itself never touches the ground or anything like that. I never had that happen even when I was at almost a 4" drop with my Nex SS coilovers.
Only problem I had with them was tire rub epecially with a passenger and in a turn on a winding road driving aggressively, or making a tight turn or going up or down a ramp.
edit - also, check ur pm
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
joflewbyu2
Aug 18, 2019 10:38 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
