Fog lights? Which provide more light?
I know that a lot of you are using the Polarmg-6's to replace the stock fogs, do those provide a better lower level of lighting? I am looking for something that closely matches the headlights but also provides an ample amout of light. Any suggestions?
I too am looking into replacing those pathetic road lights. The Polargs are 18 watts, while the standard light is 5 watts. This should in turn mean that they would provide ample lighting. In addition, I hae een the polargs comparedto the regular, and it is pretty substantial increase in light. They als match the hedlights quite well. Finally, this may b nitpicking, but I noticed that you saif fog light. The standard light is a driving light. This means that no matter what bulb you put in, it will never accomplish the same thing as a fog. If you want fogs, you can spend about $150 for PIAA Xtreme Whites. They are closer tofogs than the lights on there now.
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
Originally posted by SilverCLS
...this may b nitpicking, but I noticed that you saif fog light. The standard light is a driving light. This means that no matter what bulb you put in, it will never accomplish the same thing as a fog.
Powered By HONDA
i know the stock fog light is really weak and not bright enough.but cls' headlight is very bright enough.so i am not thinking of replacing fog light's bulb or add another set of fog light.i like the way it is (stock)
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
