Firm up steering.
Old 09-16-2013 | 11:00 PM
kingofdust's Avatar
In search of excitement
Firm up steering.
Where can I get parts to firm up my steering, feels loose and sloppy all of the sudden. I have been looking around and cant find much.
Old 09-17-2013 | 03:09 AM
Acidicheartburn's Avatar
I've been wondering the same thing. Though my steering is pretty much the same as it always has been since I got my car new, it's always been rather devoid of feedback and isn't sharp enough. It's also a rather slow steering rack. Can anything be done about that without spending hundreds if not thousands on mods? In this episode of Mighty Car Mods on youtube (http://www.youtube.com/watch?feature...-CMZmXXo#t=413) they replace a rubber steering linkage bush with an entirely metal one to get rid of "slop" in the steering. I would love to know if anything like this can or is even worth doing. I couldn't find any information on the steering linkage system in the CL after a short google search.
Your steering shouldn't feel loose and sloppy "all of a sudden". You really should get that checked out, as that sounds like something has broken.
Old 09-17-2013 | 07:33 AM
fuzzy02CLS's Avatar
The steering is typical Honda. Not much you can do. If the steering feels loose all of a sudden check your engine mounts, front sways(bushings) end links, ball joints & shocks. If your high miles & stock shocks they could be at end of life. Also check your fluid level & power steering pump. The pump could have a bad seal.
Old 09-17-2013 | 11:21 AM
kingofdust's Avatar
Yeah I guess all of the sudden is a little off putting, its just doesnt feel as firm as it used to. I was wondering if anyone made bigger tension rods for this car or anything like that but I guess not.
Old 09-19-2013 | 12:19 AM
03 tls nc's Avatar
How many miles are on your car? Like Fuzzy said there are several thing that can lead to sloppy steering. You could put a larger sway bar set on the car but if you have dead shocks and need ball joints or tie rods then you should really do the maintenance first.
Old 09-19-2013 | 07:21 AM
fsttyms1's Avatar
You mean Sway bars? Yes, there are swaybar options. By loose did you recently get new tires? What PSI is in your tires? Shocks, original or new? Radius rod bushings, control arm bushings are things that may be worn out.
Old 09-20-2013 | 03:31 PM
OperationDarkie's Avatar
Ultra Negro
Check alignment first, that sounds like your toe is off to me if the steering is loose.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
spudweb
05-22-2016 02:39 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Firm up steering.
