Feeling on 17x7.5" wheel with 235/45/17's
Well the three combo's I'm looking at are;
1. STOCK - 17x7" SSR GT1's with Toyo 215/50/17
Pros: stock size so fit will not be a problem. New springs will not cause rubbing.
Cons: stock size so I will not benefit from a larger contact patch(improving handling & traction).
2. Wide - 17x8 SSR GT1's with toyo 235-245/45/17
Pros: Bigger contact patch will increase handling and traction. Look cool![](http://www.acura-cl.com/ubb/cool.gif)
Cons: Will rub under certain driving conditions![](http://www.acura-cl.com/ubb/frown.gif)
3. Compromise - 17x7.5 SSR GT1's with Toyo 235/45/17
Pros: Bigger contact patch, increased handling and traction. No rubbing(need to look at offsets)?
Cons: Don't know any do you???
Does anyone have any experience or thoughts on the 17x7.5 wheels with 235 rubber?
2001 Silver 3.2CLS
Muds, Spoiler, Hardwire 8500, Polarg M-6 lamps, K&N filter #33-2178,
Comptech Headers, Sways, mufflers![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Planning: SSR 17X8 Competition Wheels, Brembo Brakes.
2001 Silver 3.2CLS
Location: Somewhere between here and there, yet neither.
Toyos are overrated.
2001 Cl-S Black on Black with Navigation
Black Tint all around (15%~45%)
Weapon-R Dragon Filter
Weapon-R Coil-Overs
Koni Adjustable Struts
Comptech Sway Bars
Comptech Headers (hehehe...I got something for you drchang!!)
Weapon-R Coil-Overs
Comptech Sway Bars
<font face="Verdana, Arial" size="2">Originally posted by moomaster_99:
</font>
</font>
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 9 coats of Zaino magic
</font>
</font>
I have the 17x8 SSRs, but I'm not lowered (so I don't have a problem). If you lower the car with the Comptech springs or lower, you will rub.
Also, different tires have different section widths and contact patches.
Each time you put a given size tire on a narrower wheel, you reduce the "section width" given on the tire manufacturer's spec sheet. That section with is calculated using the "measuring wheel." This is shown on most pages as the the "center" wheel width value (max, Measuring width, min) *or* there will be a color to denote it.
As you shrink the rim, you reduce this section width, here is a page on the TireRack site that tells you approximately how much.
http://www.tirerack.com/tires/tirete...l#sectionwidth
So, there is a point where a 225 on a wide wheel will rub as much as a 235 on a narrow wheel.
I wonder who is going to come forth and describe exactly where they are rubbing with their tires?
- Mud guards
- Wheel locks
- Silver AEM CAI
rockyboy
12-06-2022 02:29 PM
