Exhaust Bolts (replacing)
CL-S 6Speed is rarely in
Ok I'm a little new here and have been doing some reading and searching on doing my exhaust. Here is what I have come up with by reading and searching.
-XS Power Headers seem to be generally a good buy for most with decent power enhancement for the price.
-No real need to change the from the cat back because the Type S has a decent exhaust from the factory.
-To help with exhaust resonation header wrap can be used for good results.
-Most people found the cat bolts to be the biggest pain. Soaking all bolts being removed the night before on a cold engine and again shortly before removal will help this greatly. Pb blaster seems to be the most popular.
-For better sealing of headers replacement bolts should be used.
Following instructions for r and r on here I looked over the whole engine compartment at everything that needs to be removed to do this install. I have all tools necessary along with time and space. I'm getting my list together of parts and prices and havefound everything I need except the replacement bolts. In some posts I found people having success at home depot or napa. Does anyone have part numbers for these items? Or am I better off getting these from the dealer. I'd like to order everything Monday so I have a good chance of getting it done this weekend. Any other suggestions are appreciated. Thanks.
Joe
Joe
'03 ABP YA4-S 6MT
I apologize I didn't clarify what I meant by replacement bolts. I did read that the ones that come with the headers are crap. I didn't want to reuse my stock ones either and want to replace those. Where is the best place to get?
Good luck
Quarantuning
When choosing bolts from whatever store, remember to look for grade 8 steel or better. The bolts I used were 8.8 and had no probs tightening them down. I also recommend the header wrap at least on the cheap leaky flex pipe. My xs headers are loud!!! The sound is def coming from the flex pipe wish I had wrapped them first. Believe me its next on my list of things to do. They did give me noticeable gain in hp though. Good luck with the install, its a good mod.
Thanks for the advice. I am ordering all my stuff tonight. Definitely getting header wrap. In my search I found a spray referred to as High Heat Coating. Think I may order this too. I found two different kinds. One listed by most companies as "original" and a second listed as copper. Can anyone who's used header wrap coating give me a good suggestion? It looks like most manufacturers offerer the regular stuff in black and silver. If I go with this I will order the black. Seems like the silver would look bad after time and wear. Thanks.
Joe
Joe
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
