Engine/Trans stumbles on acceleration
Old Jul 14, 2009 | 11:07 AM
BigJack75's Avatar
I can't figure out it this is an engine issue or trans issue. I have a 03 CL-P with 103k. I just performed the 105k service outlined in the manual. I didn't notice any improvement in drivability. When I take off from a stop the shift between first and second gear is pretty rough. Almost like the injectors are clogging . It happens about 90% of the time and isn't that bad but annoying. If I take it to a dealer are they gonna charge just to look at it or is this covered in the warranty?
Old Jul 14, 2009 | 11:19 AM
Pseudomaniac's Avatar
103k yer outta luck with the dealer.
The Shift is rough like Revvvvvvvvvvvvv....Kathunk! Or You're accelerating and the car is lurching, sputtering?
Old Jul 15, 2009 | 06:00 PM
Rajca's Avatar
wham bam thank you ma'am
what spark plugs did u use? try seafoam in the intake, oil, and gas tank, if u just changed your oil, then skip the oil treatment process for now.
Old Jul 15, 2009 | 11:02 PM
'01White3.2CL's Avatar
TellinItLikeItIsSince1/06
if the "shift between first and second gear is pretty rough" ...umm, well i hope you have about $3500 saved up for the new tranny.
I really hope this isn't the case for you man, but this is how it all started for me... :-(
BTW, in your 105k service, did you change trans fluid or anything like that? i just ask b/c i had mine changed thinking i was doing good, then about 2 weeks later, my trans died on me...
Old Jul 15, 2009 | 11:10 PM
pits200's Avatar
Well the 105K mile service is the timing belt too....
Did you do this also? If so, could be a problem with the timing belt install and being off a notch or two from TDC causing the issues.
Let us know what you did for the 105k mile service and that can help.
Old Jul 16, 2009 | 06:27 AM
poisx7's Avatar
i believe u are right on the money, i wwas going to suggest the same.
So let see what he comes back with ..................
Hopefuly its just a misalignment Not a new tranny problem.
Mike734
Dec 10, 2021 01:25 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Jimmy_D
Oct 7, 2015 11:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
